Friday 19 June, 2009 Expand to read article belowIt's summer and time once again for the MASTERS worldwide conference! CCS will again be presenting the highly recommended course, “Using the CCS C Compiler for Rapid Development of Microcontroller Applications.” This is an ideal course for the new or experienced CCS C Compiler user to become better acquainted with fundamental compiler methods. Attendees learn specific techniques for 8-bit to 16-bit PIC®MCU migration, as well as CCS API for controlling the PIC®MCU peripherals; including CCS’s unique API that allows serial I/O (asynchronous, SPI, I2C™) on any GPIO pins. The hands-on portion of the class utilizes the CCS PIC16F887 prototyping board for further exploration of IDE applications, Wizards and advanced debugging techniques using the CCS In-Circuit Debugger. New features added to the compiler in the past year will also be discussed. For more detailed class descriptions and scheduled start and end times, please check the Microchip MASTERs 2009 website for CCS class number 1318.
Visit our booth at the Third Party Tool Bazaar and evaluate the CCS C Compiler with Enhanced Mid-Range Core support. Demo the all-encompassing programmer line or try the new Capacitive Touch prototyping board. New all-inclusive development kits utilizing PIC24 and the Enhanced Mid-Range Core of PIC16®microcontrollers will also be rolled out at MASTERS 2009. CCS representatives will be available for further discussion during conference.
Compilers and selected programmers will be sold on-site at the Microchip Store.
Sign-up for the raffle to win a compiler or Load-n-Go!
MASTERs is a highly technical conference hosted by Microchip in an effort to advance the knowledge of Microchip developers. This years MASTERs will be at the JW Marriott Desert Ridge in Phoenix, Arizona. The conference runs July 27- August 1. Register today, and be sure to sign up for the CCS class! | Friday 17 April, 2009 Expand to read article belowThe new faster ICD-U64 In-Circuit Programmer and Debugger is now in stock and available for purchase! The ICD-U64 is 2x faster when loading a full PIC18F4520 than the ICD-U40 and the single step in the debugger is 3x faster then MPLAB® ICD2.
Integrate the ICD-U64 with your CCS IDE Compiler for debugging or pair your ICD-U64 with Tag Connect, a cost saving revolutionary ICSP™ Programming cable for production. Also try new and improved CCSLOAD programmer control software today with the ICD-U64.
Please visit www.ccsinfo.com/programmer64 to purchase your ICD-U64 today!
Just a reminder that Masters 2009 conference is right around the corner and CCS will be teaching a C compiler class. The conference runs July 27th thru August 1st at the JW Marriott Desert Ridge Resort Phoenix, AZ. Additional class information to follow! | Monday 06 April, 2009 Expand to read article belowComplete In-Circuit Programming and Debugging with the new ICD-U64 for Microchip PIC®MCU and dsPIC®DSC devices. The ICD-U64 is faster than the ICD-U40 and will soon replace it.
Coming soon!
Special debugging capabilities for Enhanced Mid-Rang PIC16 devices
To learn more about the New ICD-U64 please visit www.ccsinfo.com/news64 | Tuesday 17 March, 2009 Expand to read article belowA new look and features have been incorporated in CCSLOAD to make programming a breeze. Key features include enhanced program security, improved diagnostics, and a new production interface.
Enhanced security options enable file wide CRC checking, failed chips to be erased and the ability to verify protected code so that it cannot be read after programming. Extensive diagnostics now allow each target pin connection to be individually tested. The PC driver tests aid in identifying specific driver installation problems.
CCSLOAD has a modern straightforward production interface. Simply point, click and program! Additions to HEX file organization include associating comments or a graphic image to a file to better ensure proper file selection for programming. Audio cues now indicate the success of your program load. The hands-free mode auto programs each time a new target is connected, allowing for quick programming in a production environment.
All CCS device programmers are supported including; ICD-U40, ICD-S40, Mach-X, Load-n-Go, and PRIME8. CCSLOAD stand-alone software can be used by PCW customers wanting to program with Microchip MPLAB®ICD 2, MPLAB®ICD 3 or MPLAB®REAL ICE™programmers.
Experience CCSLOAD and its powerful command line options today! Go to ccsinfo.com/downloads
To check out additional CCSLOAD features at www.ccsinfo.com/ccsloadfeatures | Tuesday 17 March, 2009 Expand to read article belowIntroducing Tag Connect, a new production ICSP™ programming cable that eliminates the need for a ICSP™ connector on your product. Tag Connect uses a direct pin-to-circuit connection that allows the connector to "plug" directly into the PCB. Simply add the connector footprint at the time of PCB production and you are set! By eliminating the connector, PCB space is gained and overall cost of the board is reduced. Tag Connect provides ICSP™ Program/Debug capabilities and is equipt with a modular end that works with existing ICD programmers on the market. Tag Connect works with all CCS programmers and debuggers- both new and old!
Currently CCS is the exclusive distributor of Tag Connect. Learn more about how Tag Connect can save you money at www.ccsinfo.com/tagnews! | Monday 26 January, 2009 Expand to read article belowA beta version of CCSLOAD, the programmer control software, is ready to try! Now supports all CCS device programmers including; ICD-U40, ICD-S40, Mach-X, Load-n-Go, and PRIME8.
CCSLOAD features better support for multiple device programmers on the same PC, new hands-free mode in the production programming window, more descriptive error messages and diagnostics that enable extensive checking of hex files, programmers, and targets to identify problems and much more!
There are three styles of the program available for download; each built to cater to specific customer needs- you pick the program that best fits your application!
1.CCSLOAD.EXE may be used as a Windows GUI program or as a command-line operated program with pop-up windows
2.CCSLOADER.EXE a command-line only version of the program (no pop-up windows)
3.ccsloader.exe for our Linux customers
Beta available for download at www.ccsinfo.com/ccsload
To learn more about CCSLOAD click here | Friday 23 January, 2009 Expand to read article below Take this limited-time survey and get a free gift or discounts from CCS. This is your chance to offer real-world experience and information on 8-bit microcontrollers and development tools.
To take the survey please click here or go to www.ccsinfo.com/survey2009
Not interested? Please pass this information and link on to friends or co-workers! | Monday 22 December, 2008 Expand to read article belowWe would like to wish you Happy Holidays! A reminder to our customers and vendors that we will be closed December 24th-28th and December 31-January1st. During this time orders will not be processed, so please plan accordingly. Technical Support emails may have delay in prompt/immediate responses. Phone support will not be available- please email. We would like to thank you for your business and we look forward to an exciting new year!
| Monday 22 December, 2008 Expand to read article belowYou can now use the MPLAB®ICD 3 with the CCS IDE Compiler (PCW, PCWH, PCDIDE or PCWHD). You can program and debug within the windows environment using a MPLAB®ICD 3.
Here are a few simple steps to follow when using the CCS IDE Compiler with MPLAB®ICD 3:
- Must have version 4.084 or higher of the CCS IDE Compiler
- Download MPLAB®ICD 3 interface module from the CCS Downloads Page. This download is free.
- Have MPLAB® already installed.
- The debug environment is built-in to the C Aware Real-Time Debugger, once the hardware is connect to your PC, select the programmer/debugger you would like to use from the "Debug Configure" option on the IDE menu tab. All CCS Command-Line Compilers (PCB,PCM, PCH and PCD) can also be integrated with MPLAB®ICD 3.
If you have questions or concerns regarding integration please contact sales@ccsinfo.com
| Tuesday 04 November, 2008 Expand to read article belowMicrochip Technology Inc. has announced an enhancement to the microcontroller (MCU) architecture in the Mid-range 8-bit Family. CCS has already been working on the support for the new family. The PCM command-line and PCW IDE compilers beginning with version 4.100 will have support for the new architecture.
Fundamental compiler enhancements include reduced system functions being in-lined with the 16 level call stack, using the more efficient MOVLP for page switches, built-in functions for enhanced peripherals, automatic translation for old or hard-coded address to use newly assigned SFR registers, and using the two FSRs for a reduction in the number of instructions. Substantial improvements on Constant String allows for access of ROM in the normal RAM address space, no special handling at the C level for Pointers to ROM to be interchanged with RAM pointers, and no limit on constant data structure size.
In an effort to best support the new architecture, CCS has made all the string functions as Built-Ins, to maximize the optimization. This has inspired us to also extend some of this optimization to all 14 & 16-bit devices. Beginning with version 4.100, all string operations will be more flexible (mixing ROM and RAM) and efficient.
Adding even more value to the IDE compilers, CCS is including a new Menu Manager. This allows for the creation of character LCD or segmented LCD menu systems at the PC. C code is then generated as an include file for your project.
Advanced debugging support for the new capabilities in these parts will be in the IDE compilers. The CCS ICDs, MachX, Load-n-Go and PRIME8 programmers will also support the Enhanced Mid-range devices.
Click here to get more information on Compiler Support by CCS
For additional information on the Enhanced Mid-rage 8-bit PIC Microcontroller Core, visit microchip.com |
