CCS Video Tutorials
All CCS Video Tutorials are .wmv files. Windows Media Player is needed for viewing.
Subscribe to our YouTube channel (CCSIncTube) to stay updated on the latest videos.
CCS C Compiler | Programming & Debugging | Development Boards | Inspired PIC® Projects
CCS C Compiler
C Compiler Quick Start
Duration: 6:40
C Compiler Quick Start (YouTube)
Go from a blank sheet of paper to a blinking LED in less than 5 minutes! You will learn how the CCS color coded text editor simplifies design entry. See how CCS provided built-in functions speed up software development. Quickly locate and correct design errors. Program devices in-circuit and modify the blink rate on the fly with the CCS ICD-U80 In-circuit Programmer/Debugger.
CCS C Compiler IDE Coding Tips
Duration: 2:03
CCS C Compiler IDE Coding Tips (YouTube)
This short video goes through 5 helpful tips for writing C code in the CCS IDE.
Functions Level 1 Video
Duration: 5:03
CCS C Compiler Built-in Functions - Level 1 (YouTube)
Learn about built-in functions related to blinking an LED, reading a button press, using UART, collecting analog sensor data, storing data in an internal EEPROM, and generating PWM. Download the zipped file containing the code for the Built-in Functions video series.
Functions Level 2 Video
Duration: 6:45
CCS C Compiler Built-in Functions - Level 2 (YouTube)
Learn about built-in functions related to using a timer interrupt, setting up an external interrupt, streaming data through the ICD, writing to an external EEPROM, and starting a watchdog timer. Download the zipped file containing the code for the Built-in Functions video series.
Edit Menu Video
Duration: 1:52
CCS C Compiler IDE Menu: Edit (YouTube)
Topics include selecting code formatting options and learning how to record keystrokes.
Search Menu Video
Duration: 2:23
CCS C Compiler IDE Menu: Search (YouTube)
Topics include learning how to search for a string and setting bookmarks in the code.
Options Menu Video
Duration: 11:04
CCS C Compiler IDE Menu: Options (YouTube)
Topics include changing how the IDE looks and operates, setting where the project output files will be put, and configuring the software update utility.
Compile Menu Video
Duration: 4:34
CCS C Compiler IDE Menu: Compile (YouTube)
Topics include learning the differences between Compile, Build, and Rebuild and explaining some of the output files.
View Menu Video
Duration: 10:18
CCS C Compiler IDE Menu: View (YouTube)
Topics include finding chip information, displaying project statistics, and learning how to manage and compare project history files.
Tools Menu Video
Duration: 11:07
CCS C Compiler IDE Menu: Tools (YouTube)
Topics include monitoring the serial port, learning how to profile a program while it is running, and converting any file to a valid C data structure.
Debug Menu Video
Duration: 6:00
CCS C Compiler IDE Menu: Debug (YouTube)
Topics include using the debugger, setting a breakpoint, and watching a variable.
Document Menu Video
Duration: 3:56
CCS C Compiler IDE Menu: Document (YouTube)
Topics include learning how to generate documentation, using the flow chart editor program, and performing spell check inside quotes and comments.
Help Menu Video
Duration: 5:41
CCS C Compiler IDE Menu: Help (YouTube)
Topics include finding information about built-in functions and looking up which versions of the IDE and compiler are installed.
Getting Started with EZ App Lynx
Duration: 8:37
Getting Started with EZ App Lynx (YouTube)
Use the EZApp library to quickly create a wireless sensor or controller on a PIC® MCU that may be viewed and displayed on a mobile device using Bluetooth® wireless technology included in CCS IDE Compilers. You will learn how EZ App Lynx works and how to program the bootloader onto the chip.
Using CCS C Compiler in MPLAB X
Duration: 6:25
Using CCS C Compiler in MPLAB® X (YouTube)
In this video tutorial, we demonstrate how to use the CCS C compiler within MPLAB® X! You will learn how to install the CCS Plug-in in MPLAB® X, set up a new project in MPLAB® X, add an existing C source file to the project, compile and debug the project, find output files, and program the chip.
Troubleshooting Problems with the CCS Plug-in for MPLAB® X
Duration: 7:31
Troubleshooting Problems with the CCS Plug-in for MPLAB® X (YouTube)
In this video, we walk through some of the common problems that users face when using the CCS plug-in in MPLAB® X and how to fix them.
Unable to Detect USB Connected Programmer Video
Duration: 4:51
Unable to Detect USB Connected Programmer (YouTube)
Learn from CCS development engineers how to quickly resolve hardware and hookup problems with diagnostic utilities built into CCSLOAD.
Unable to Detect Serial Connected Programmer Video
Duration: 1:59
Unable to Detect Serial Connected Programmer (YouTube)
Unable to Detect Target Video
Duration: 5:09
Unable to Detect Target (YouTube)
Using the CCSLOAD Software with the ICD-U64
Duration: 5:35
Using the CCSLOAD Software with the ICD-U64 (YouTube)
In this video tutorial, we demonstrate how to use the CCSLOAD software with the ICD-U64 to program hex files to one or more PIC development boards! You will learn how to install the CCSLOAD software and USB drivers, setup the ICD-U64 with a workstation, and use CCSLOAD to test the connection to the chip, program a hex file to one or more boards, and view programming results.
Data Streaming
Duration: 5:36
Data Streaming (YouTube)
Eliminate a diagnostic serial port and save money by streaming data through the ICSP interface instead! You will learn how to modify one line of source code in an existing design to stream data through the ICSP port. See how to use the ICD-U64 programmer/debugger as a serial communications link between the target board and host PC. View input and output waveforms on the host PC using the CCS Serial Port Monitor. Modify operating parameters without reloading a new software image.
Mobile In-Circuit Programming
Duration: 6:51
Mobile In-Circuit Programming (YouTube)
Update your stand-alone products in the field without the need of a PC! You will enable your field support technicians and engineers to load new software in deployed products and keep them running at peak performance. See how to use CCSLOAD programmer control software to store programs in the LOAD-n-GO hand-held programmer for multiple product configurations. Learn how to quickly locate and resolve programming issues and how the battery operated LOAD-n-GO can program devices in-circuit, even when the target system is powered down.
Prime8 Production Programmer
Duration: 9:03
Prime8 Production Programmer (YouTube)
This video details the three main features of the CCS Prime8 Production Programmer, PC programming, Standalone Mode and Programming from a USB Drive. Streamline your manufacturing process with the Prime8!
ICD-U64 Example (Video in Spanish)
Duration: 11:03
Ejemplo de acceso a datos de depuración a través de la interfaz ISCP y el programador/depurador ICD-U64 de CCS.
Development Boards
CCS Touchscreen Interface Designer
Duration: 9:34
CCS Touchscreen Interface Designer (YouTube)
This video is an introduction to the CCS C Compiler's feature, Interface Designer, which can be used to build user interfaces for touchscreen devices.
Getting Started with the LoRaWAN® Modules
Duration: 4:44
Getting Started with the LoRaWAN® Modules (YouTube)
Learn about the advantages of using LoRa and LoRaWAN® technologies. We'll explain how the examples and drivers included in the Long Range RF Development Kit can help you quickly get started with connecting to a LoRaWAN® network or a LoRa peer-to-peer network.
Getting Started with the E3mini Development Board Video
Duration: 4:58
Getting Started with the E3mini Development Board (YouTube)
Get started with the E3mini development board. You will learn how to install the compiler software and compile and download a program to the board.
Note: If you have received a 'Timeout' error, click here to find out how to resolve the issue.
Troubleshooting Problems with the E3mini Development Board Video
Duration: 4:35
Troubleshooting Problems with the E3mini Development Board (YouTube)
Troubleshoot problems with the E3mini development board when you are unable to download software to it. You will learn how to troubleshoot possible problems with the board.
RGB LED Lights
Duration: 7:10
RGB LED Lights Video (YouTube)
Learn how to program a touchscreen interface with a PIC24EP512GU810 to control a grid of RGB LED lights! The touchscreen can be used to change the text displayed and the brightness, flashing rate, and color of the RGB LED lights. The LED display uses PIC® processors and consists of 16 rows and 16 columns of lights, creating a grid of 256 LEDs.
Soccer Robots
Duration: 0:44
Soccer Robots Video (YouTube)
Two robot cars face off against each other on the soccer field. Players use the EZ App Lynx app to control the robot cars from their iPads. The robot cars are made out of sensors and a prototyping board.
Rube Goldberg Machine
Duration: 0:35
Rube Goldberg Machine Video (YouTube)
This Rube Goldberg machine uses various sensors in a chain of reactions that ultimately ends with a gumball rolling out of the Gumball machine. The only motion needed to start the machine is a clap from the hands. The processors used in this machine were all easy-to-use CCS E3mini boards that have a PIC® processor programmable from a USB port.
Lab Stir Stick Sensor Video
Duration: 0:34
Lab Stir Stick Sensor Video (YouTube)
See a PCB stick in a chemistry beaker read the temperature and light. The EZApp library is used to display those results on a tablet!
Robot Arm
Duration: 0:45
Robot Arm Video (YouTube)
The robot arm is programmed to complete the Tower of Hanoi or can be in manual mode to be controlled from the tablet. The four colored blocks have pegs for the robot arm to grab and easily move the block. The tablet uses EZ App Lynx for displaying the robot arm controls.
Plinko Game
Duration: 0:05
Plinko Game Video (YouTube)
Drop a puck into the Plinko game and watch the line drawn on a tablet screen via Bluetooth® wireless technology! The Plinko board has an array of light sensors between the pegs. When the puck passes over and blocks the light to the sensor, a command is sent to the PIC® microcontroller. The PIC® MCU talks to a Bluetooth® module to send the sensor coordinate to the application running on the tablet. As the coordinates are sent, a line is drawn showing the path of the the falling puck.
Having trouble watching a video tutorial? Email CCS for support.
