How do I write variables to EEPROM that are not a byte?
The following is an example of how to read and write a floating point number from/to EEPROM. The same concept may be used for structures, arrays or any other type.
  • n is an offset into the eeprom.
  • For example if the first float is at 0 the second
  • For floats you must increment it by 4.
  • one should be at 4 and the third at 8.
WRITE_FLOAT_EXT_EEPROM(long int n, float data) {
   int i;
   for (i = 0; i < 4; i++)
      write_ext_eeprom(i + n, *((int8*)&data + i) ) ;
float READ_FLOAT_EXT_EEPROM(long int n) {
   int i;
   float data;
      *((int8*)&data + i) = read_ext_eeprom(i + n);
   return(data);
