How can I pass a variable to functions like OUTPUT_HIGH()?
Using the Version 5 and up compilers, the I/O functions accept a variable. For older compiler versions, use the following techniques:
switch(pin_to_use) {
case PIN_B3 : output_high(PIN_B3); break;
case PIN_B4 : output_high(PIN_B4); break;
case PIN_B5 : output_high(PIN_B5); break;
case PIN_A1 : output_high(PIN_A1); break;
If you need to use any pin on a port use:
#byte portb = 6 #byte portb_tris = 0x86 // ** portb_tris &= ~(1<<bit_to_use); // ** portb |= (1<<bit_to_use); // bit_to_use is 0-7
If you need to use any pin on any port use:
*(pin_to_use/8|0x80) &= ~(1<<(pin_to_use&7)); // ** *(pin_to_use/8) |= (1<<(pin_to_use&7));
In all cases pin_to_use is the normal PIN_A0... defines.
** These lines are only required if you need to change the direction register (TRIS).
