I installed my new registration files but my files are too old.
Sometimes older registration files on your PC will overwrite the new ones that you try to install. To fix this problem, delete every registration file on your PC and then re-copy your new registration files off your CD-ROM or email (be sure to check your Temp directory or do a search). This should solve the problem.
If you want to keep old compilers (which may be important for some users), create a new directory for each compiler.
