How can I use your compiler with MPLAB® IDE?
A plug-in is available on our website that you can install if you wish to use the MPLAB® IDE with our compiler. With this plug-in, you can use the MPLAB® IDE to edit and build projects using the CCS compiler. You must choose the CCS C Compiler in the pull-down bar.
You can download the plug-in from this page: www.ccsinfo.com/downloads.php
