How do you view float variables inside MPLAB® IDE?
When you add a watch for a float variable MPLAB commonly only watches it as an 8bit register. In the Watch Window, highlight the float register you want to watch and right click and choose properties. A dialog box will open, you will want to change the properties to these settings:
Format: MCHP Float
Byte Order: Low:High
