I found a bug in the compiler.
If you report a bug to tech support via e-mail while on active maintenance, you will be entitled to the version fix, even if your maintenance expires before the newer version is released. You must email tech support to receive this option.
Maintenance purchase is required to receive update to the bug fix, if reporting a bug while out of your maintenance period.
