jaymiller Guest
MPLAB7.51 build failure |
Posted: Fri Jan 26, 2007 8:36 pm |
Ok, so I decide to 'upgrade' to MPLAB 7.51 from 4.99 and the install is ok. creating asm code works...Download and install the CCS 'magic program' to allow MPLAB to see my PCM ( Version 2.624). It kinda works but erros out as a 'build failure'.I'm not impressed,mega power program craps out without a hint of WHY! I can import the .hex file that MP4.99 creates before it dies(white screen close-ignore)(that's why I 'upgraded...') and MP7.51 will program the chip just fine,dissemble,etc.
Any ideas what's going on??? Yes I know V2.624 is old but then so am I, and it has worked for me for years.
Thanks for any help.
Jay in snowy Greensville,Ontario |
jaymiller Guest
mplab |
Posted: Sat Jan 27, 2007 6:57 am |
Hello again PCM programmer.Ok,I've 'uninstalled MPLAB7.51,7.50 and 5.7'. Installed 5.7 again. My PCM is in c:\PICC. When I try to build I get the error 'Selectcted Build Tool not correctly installed'. I did run from DOS, ccsc.exe -setup.thinking that would be the cure'. Same message.
I need just a bit more help...arrgh, and another coffee !
Thanks at least 5.7 doesn't crash.
jaymiller Guest
mplab.... |
Posted: Sat Jan 27, 2007 8:27 am |
OK, finally got it to work! Had to go int the Edit project>Node Properies>select PCM.
Now it Builds(compiles) OK.
arrrghhhh......
Thanks PCMprogrammer,I'll stick with MPLAB5.7...now that both ASM and C are working.
