sorasit46
What wrong in my code? send & receive serial data. |
Posted: Sat Feb 28, 2009 8:21 pm |
Please help!
Why not work?
Tx send
#include <16F886.h>
#device ADC=10
#define CLOCK_SP 4000000
#fuses hs,NOLVP,WDT,NOPROTECT,NOPUT,NOBROWNOUT,NOCPD,NOWRT,NODEBUG
#use delay (clock=CLOCK_SP)
#use fast_io(A)
#use fast_io(B)
#byte port_b=6
#byte OSCCON = 0x08F
#define SendData PIN_B2 // send serial data to 12F675
void tx0 (void) // send bit 0
{output_high (SendData);delay_us (250);output_low (SendData);delay_us (250);}
void tx1 (void) // send bit 1
{output_high (SendData);delay_us (500);output_low (SendData);delay_us (500);}
void txbyte (char x) // send one byte
char i;
for (i=0;i<=7;i++)
if ((x & 1)==1) tx1 (); else tx0 ();
x >>= 1;
void txsend (char x)
txbyte (0); // preamble
txbyte (0);
tx1 (); // start
txbyte (0x2); // code1
txbyte (0x4); // code2
txbyte (0x6); // code3
txbyte (0x8); // command
tx0 (); // end
Void main()
OSCCON=0x60; // set int-osc 4 Mhz
while ((OSCCON&0x4)!=0x4); // wait for clock stable
setup_ccp1(CCP_CAPTURE_FE);
setup_ccp2(CCP_OFF);
enable_interrupts(INT_CCP1);
setup_adc_ports(sAN0 | sAN4);
setup_adc(adc_clock_internal);
setup_spi(FALSE);
set_timer0(0);
setup_timer_1(T1_DISABLED);
set_tris_a(0b00110001);
set_tris_b(0xFA);
set_tris_c(0b00001101);
output_low(SendData);
setup_wdt(WDT_2304MS);
restart_wdt();txsend (0x6);restart_wdt();
Tx receive
#include <12F675.h>
#device adc=10
#FUSES NOWDT,INTRC_IO,NOCPD,NoPROTECT,NOMCLR,PUT,NOBROWNOUT
#byte OSCCON = 0x8F
#define Confirm PIN_A2 // confirm can get data
#define Datain PIN_A3 // serial data from 16F886
int16 rxbit (void) // check bit cycle
int16 x;
x = 0;
while (input (IRWork)==1) x++;
while (input (IRWork)==0) x++;
return (x);
void rxpre (void) // check preamble
int16 x;
char c;
c = 0;
while (c<5) // check bit 0
x = rxbit ();
if (x>=33 && x<=37) c++; else c = 0;
while (x<53)
x = rxbit (); // check bit 1
char rxbyte (void) // read one byte
char x,i;
x = 0;
for (i=0;i<=7;i++)
x >>= 1;
if (rxbit ()>53) x |= 0x80;
return (x);
char rxrecv (void) {
char i,j,a,x;
rxpre ();
i = rxbyte ();
j = rxbyte ();
a = rxbyte ();
x = rxbyte ();
if (i==0x2 && j==0x4 && a==0x6 ) return (x); // match
else return (0xff); // not match
char x;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
disable_interrupts(GLOBAL);
setup_counters (RTCC_INTERNAL,RTCC_DIV_1);
set_tris_A(0x1B);
output_low(Confirm);
x=rxrecv();
if (x==0x8) output_high(Confirm); else output_low(Confirm);
Regards |
asmallri
Posted: Sun Mar 01, 2009 1:25 pm |
On the TX side you have set the HS fuse but the clock parameter says you are only running at 4MHz.
So are you running at 4MHz or are you using HS? _________________ Regards, Andrew
Posted: Sun Mar 01, 2009 2:58 pm |
Worse, he appears to be trying to use the internal RC oscillator.
If you want to use this, use the INTRC fuse, and stop fiddling with the OSCCON register. Doing this will override the oscillator adjustment factor automatically loaded from the chip at boot, and the oscillator will never start, since HS, won't run without an external resonator. I wonder if in fact he has deleted the adujstment factor in the past so INTRC won't work?. If so, do a search here on how to reload this with a #rom statement.
sorasit46
Posted: Sun Mar 01, 2009 8:29 pm |
Ttelmah wrote: | Worse, he appears to be trying to use the internal RC oscillator.
12F675 use INTRC (4MHz). 16F886 use HS (4MHz) .
You mean my phoblem is 12F675 use INTRC. but 12F886 use HS.
regards |
