What wrong in my code? send & receive serial data.
sorasit46
PostPosted: Sat Feb 28, 2009 8:21 pm     Reply with quote
Please help!
Why not work?
Tx send
#include <16F886.h>
#device  ADC=10
#define  CLOCK_SP   4000000
#fuses   hs,NOLVP,WDT,NOPROTECT,NOPUT,NOBROWNOUT,NOCPD,NOWRT,NODEBUG
#use     delay (clock=CLOCK_SP)
#use     fast_io(A)
#use     fast_io(B)
#byte    port_b=6
#byte    OSCCON = 0x08F
#define  SendData PIN_B2            // send serial data to 12F675
void tx0 (void)                  // send bit 0
{output_high (SendData);delay_us (250);output_low (SendData);delay_us (250);}
void tx1 (void)                  // send bit 1
{output_high (SendData);delay_us (500);output_low (SendData);delay_us (500);}
void txbyte (char x)             // send one byte
    char i;
    for (i=0;i<=7;i++)
        if ((x & 1)==1) tx1 (); else tx0 ();
        x >>= 1;
void txsend (char x)
    txbyte (0);                                        // preamble
    txbyte (0);
    tx1 ();                                            // start
    txbyte (0x2);                                      // code1
    txbyte (0x4);                                      // code2
    txbyte (0x6);                                      // code3
    txbyte (0x8);                                      // command
    tx0 ();                                            // end
Void     main()
 OSCCON=0x60;                                         // set int-osc 4 Mhz
 while ((OSCCON&0x4)!=0x4);                           // wait for clock stable
 setup_ccp1(CCP_CAPTURE_FE);
 setup_ccp2(CCP_OFF);
 enable_interrupts(INT_CCP1);
 setup_adc_ports(sAN0 | sAN4);
 setup_adc(adc_clock_internal);
 setup_spi(FALSE);
 set_timer0(0);
 setup_timer_1(T1_DISABLED);
 set_tris_a(0b00110001);
 set_tris_b(0xFA);
 set_tris_c(0b00001101);
 output_low(SendData);
 setup_wdt(WDT_2304MS);
       restart_wdt();txsend (0x6);restart_wdt();
Tx receive
#include <12F675.h>
#device  adc=10
#FUSES NOWDT,INTRC_IO,NOCPD,NoPROTECT,NOMCLR,PUT,NOBROWNOUT
#use   delay(clock=4000000)
#byte  OSCCON = 0x8F
#define Confirm  PIN_A2           // confirm can get data
#define Datain   PIN_A3           // serial data from 16F886
int16 rxbit (void)                // check bit cycle
    int16 x;
    x = 0;
    while (input (IRWork)==1) x++;
    while (input (IRWork)==0) x++;
    return (x);
void rxpre (void)                // check preamble
    int16 x;
    char c;
    c = 0;
    while (c<5)                  // check bit 0
        x = rxbit ();
        if (x>=33 && x<=37) c++; else c = 0;
    while (x<53)
        x = rxbit ();             // check bit 1
char rxbyte (void)               // read one byte
    char x,i;
    x = 0;
    for (i=0;i<=7;i++)
        x >>= 1;
        if (rxbit ()>53) x |= 0x80;
    return (x);
char rxrecv (void) {
    char i,j,a,x;
    rxpre ();
    i = rxbyte ();
    j = rxbyte ();
    a = rxbyte ();
    x = rxbyte ();
    if (i==0x2 && j==0x4 && a==0x6 ) return (x);    // match
    else return (0xff);                             // not match
 char    x;
 setup_adc_ports(NO_ANALOGS);
 setup_adc(ADC_OFF);
 disable_interrupts(GLOBAL);
 setup_counters (RTCC_INTERNAL,RTCC_DIV_1);
 set_tris_A(0x1B);
 output_low(Confirm);
       x=rxrecv();
       if (x==0x8) output_high(Confirm); else  output_low(Confirm);
Regards
asmallri
PostPosted: Sun Mar 01, 2009 1:25 pm     Reply with quote
On the TX side you have set the HS fuse but the clock parameter says you are only running at 4MHz.
So are you running at 4MHz or are you using HS?
Regards, Andrew
PostPosted: Sun Mar 01, 2009 2:58 pm     Reply with quote
Worse, he appears to be trying to use the internal RC oscillator.
If you want to use this, use the INTRC fuse, and stop fiddling with the OSCCON register. Doing this will override the oscillator adjustment factor automatically loaded from the chip at boot, and the oscillator will never start, since HS, won't run without an external resonator. I wonder if in fact he has deleted the adujstment factor in the past so INTRC won't work?. If so, do a search here on how to reload this with a #rom statement.
sorasit46
PostPosted: Sun Mar 01, 2009 8:29 pm     Reply with quote
12F675 use INTRC (4MHz). 16F886 use HS (4MHz) .
You mean my phoblem is 12F675 use INTRC. but 12F886 use HS.
regards
