The microchip ICD2 can supply 5V to the target circuit, can the ICD-U40 do the same? I did not see anything in the ICD software to enable/disable 5V to the target.
If not can it be modified (software/hardware) to provide this functionality?
This ICD unit connects to the PC and the debugging software over USB (USB cable included). The ICD-U40 Unit is powered from the USB bus. It can also power a board @5V by closing the jumper near the ICD jack inside the unit (the unit must be opened).
ktallevi
Posted: Thu Mar 13, 2008 12:58 pm
thanks guys, it works. Not sure how I missed that, its clearly documented :)
