Has anyone here successfully wired up a PIC24F and programmed with either the ICD or MachX yet? I believe CCS has does this with demo boards, but not the DIP chips... I am doing this through the ICSP cable not the ZIF socket. The chip I am using is the PIC24FJ64GA002.
robi77
Posted: Tue Oct 09, 2007 6:18 am
hi!
I was tried to use same ic, but it same not worked.
PIC24FJ64GA002-I/SO
Im was checked with an oscilloscope and the icd diagnostic, but the clock and data pins dont do the expected waveform.
