16-bit PIC + ICD/MachX
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
Justin
PostPosted: Tue Oct 02, 2007 9:11 am     Reply with quote
Has anyone here successfully wired up a PIC24F and programmed with either the ICD or MachX yet? I believe CCS has does this with demo boards, but not the DIP chips... I am doing this through the ICSP cable not the ZIF socket. The chip I am using is the PIC24FJ64GA002.
robi77
PostPosted: Tue Oct 09, 2007 6:18 am     Reply with quote
hi!
I was tried to use same ic, but it same not worked.
PIC24FJ64GA002-I/SO
Im was checked with an oscilloscope and the icd diagnostic, but the clock and data pins dont do the expected waveform.
Somebody have any success with this PIC?
kYlee
PostPosted: Sat Nov 03, 2007 4:38 am     Reply with quote
use brenner 9 Smile
hxxp : / / sprut.de / electronic / pic / projekte / brenner9 / index . hxm
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
