MACH-X in the CCS IDE
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
hillcraft
PostPosted: Thu Aug 04, 2005 3:43 am     Reply with quote
Is there a painless way to use the programmer from within the IDE. I use MACH-X for bulk programming and the ICD for in-cercuit stuff. I find having to switch out of the IDE to use MACH-X to be a serious irritation.
Neutone
PostPosted: Thu Aug 04, 2005 12:27 pm     Reply with quote
I'm wondering why you would want to use the IDE for bulk programming?
hillcraft
PostPosted: Fri Aug 05, 2005 12:04 am     Reply with quote
The point is not whether I wnat to use the IDE for bulk programming or not, the point is that I would expect to be able to use a CCS supplied programmer from within the IDE. There are times when I am unable to program in-circuit, I am then forced to remove the chip from the circuit and place it in the programmer. I just think it strange that MACH-X cannot be accessed from the IDE considering that it also sports a ICD connector...
Neutone
PostPosted: Fri Aug 05, 2005 8:59 am     Reply with quote
In the IDE click on options-debugger/Programmer
Type in MACH-X where is says Warp13
I dont know the command line arguments for the MACH-X.
Harry Mueller
PostPosted: Tue Oct 18, 2005 12:40 pm     Reply with quote
I've tried setting it up using the given parameters but it doesn't seem to work.
Harry
hillcraft
Mach-X in the IDE
PostPosted: Tue Oct 18, 2005 2:20 pm     Reply with quote
Mine works perfectly thanks to Neutone.
I will take a look at the setting at the office in the morning.
hillcraft
Here are my Mach-X settings
PostPosted: Wed Oct 19, 2005 4:53 am     Reply with quote
C:\PROGRA~1\PICC\MACHX.EXE "-T%H" "%D"
Harry Mueller
PostPosted: Wed Oct 19, 2005 7:26 pm     Reply with quote
Hmmm....nothing happens.
I enter the path that you gave me in Options/ Debugger/Programmer/ Device Programmer and expect the programmer to become active when the compile has been completed. It doesn't even transfer to it if it's also open on the desktop.
Did you reference it anywhere else? Or make any oither changes in the MachX s/w?
Thanks....Harry
Neutone
PostPosted: Thu Oct 20, 2005 7:30 am     Reply with quote
After you compile click on Tools/MACH-X. You can also put a button on the toolbar.
Harry Mueller
PostPosted: Fri Oct 21, 2005 2:30 pm     Reply with quote
It's still not working for me. I've added the programmer path under Options/Programmer/Deb.... Then I compiled a file without MachX being open on the desktop and clicked on the MachX icon I had installed.
A dialog box appeared called Start connection. Within it was the heading: ICD Connection Settings and a menu to choose CCS MACHX, Com1 or Com2. IF I choose CCS MACHX It tell me that it"cannot connect. The ICD firmware is not supported". ThenI have to choose "ABORT" and it kicks me out of the program. If I choose Com1, it tells me a certain file is unavailable and I also have to abort.
What's happening? Harry
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
