rs232 prints rubish
Goto page Previous  1, 2, 3  Next
scanan
PostPosted: Fri May 09, 2025 7:53 am     Reply with quote
temtronic wrote:
curious....
you've made several changes so could you please post the program and the printout ?
thanks
set_tris_a(0b00001000); //0x08
set_tris_b(0b11000100); //0xC4
set_tris_c(0b10100000); //0xA0
set_tris_d(0b00000000); //0x00
set_tris_e(0b00001000); //0x08
TX and RX are situated at pinc6 and c7 respectively
#use delay(clock=64000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
void version(void)
//-- firmware version
printf("\r\nTelemmote Receiver\r\n");
printf("TLM-02\r\n");
printf("Firmware v1.00\r\n");
printf("Compiled on \r\n");
printf(__DATE__);
printf("\r\n");
printf(__TIME__);
printf("\r\n");
should work flawlesly but result is
U V W $ Y YZ Y C irmware v1.00
Compiled on
07-May-25
11:20:24
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Fri May 09, 2025 9:13 am     Reply with quote
Hmm....you don't have the 'delay_ms(250);' just before the first print.
allenhuffman
PostPosted: Fri May 09, 2025 9:54 am     Reply with quote
One of the four PIC24 boards I maintain had an issue with unreliable serial output, and it ended up being caused by a timer ISR. I had to move it to a different timer and then the output worked fine.
I have no idea why that was, but left myself a TODO in the comments to look into it... some day.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
PostPosted: Fri May 09, 2025 11:38 am     Reply with quote
Show your fuses.
How is the 64MHz generated????.
Show how the main code starts, and calls 'version'.
Did PUT make no difference at all?.
PostPosted: Fri May 09, 2025 2:44 pm     Reply with quote
we really need to see the complete program !
PostPosted: Fri May 09, 2025 11:54 pm     Reply with quote
More to the point, you really need to generate a basic test program that just
shows the issue. Simple main, and the code to call the version display.
Doing this then proves there isn't something hidden causing the issue as
Allen describes. Then post this.
scanan
PostPosted: Mon Sep 15, 2025 7:30 am     Reply with quote
temtronic wrote:
curious....
thanks
solved the problem by adding
fputc(0); before all printfs.
Dr Suleyman CANAN
PostPosted: Mon Sep 15, 2025 7:55 am     Reply with quote
That is interesting. Are you using some form of wireless connection?.
It sounds as if it needs to see the serial line actually transitioning high
to low to wake something up on the connection you have.
scanan
PostPosted: Mon Sep 15, 2025 8:51 am     Reply with quote
At startup ok I get What I want but when I put printf here and there for debugging
I get garbages
I get same result whit my PIC18f65k40.
I am using TTL ftdi USB converter. for connecting to my pc
Dr Suleyman CANAN
PostPosted: Mon Sep 15, 2025 8:57 am     Reply with quote
Disable the WDT. If its setup wrong, can cause random garbage.....
WDT should only be enabled AFTER 100% of the program is 100% running properly, then you determine the WDT 'time out', code that, then test for a week.
scanan
PostPosted: Mon Sep 15, 2025 9:18 am     Reply with quote
#FUSES NOEXTOSC,RSTOSC_HFINTRC_64MHZ //1
#FUSES NOCLKOUT,NOCKS//3
#FUSES NOFCMEN,NOMCLR,PUT,NOLPBOR,NOBROWNOUT //4
#FUSES ZCDDIS,NOPPS1WAY,NOSTVREN //6
#FUSES NODEBUG,NOXINST//,WDT1024 //7
#FUSES NOWDT,WDT_SW//10
#FUSES WRT,WRTC,NOWRTB,NOWRTD
#FUSES NOSCANE,NOLVP,NOPROTECT,NOCPD
#FUSES EBTR,EBTRB //15
#use delay(clock=8000000)
#use rs232(baud = 9600, parity = N, xmit = PIN_C6, rcv = PIN_C7, bits = 8)
setup_wdt(WDT_OFF);
setup_adc(ADC_OFF);
setup_adc_ports(NO_ANALOGS);
//setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
////clock 16MHZ 16000000/16/4=250000Hz (1/250000)*prescaler=interrupt period overflow time(1 ms) prescaler=65285
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_4); //| RTCC_8_BIT);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_timer_2(T2_DISABLED, 0xFF, 0x10);
setup_timer_3(T3_DISABLED);
//setup_comparator(NC_NC_NC_NC);
setup_comparator_1(NC_NC);
setup_comparator_2(NC_NC);
setup_comparator_3(NC_NC);
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
setup_oscillator(OSC_HFINTRC_8MHZ );
clear_interrupt(INT_EXT1);
clear_interrupt(INT_EXT2);
handle_test_leds(1);
delay_ms(1500);
handle_test_leds(0);
version();
ext_int_edge(1, L_TO_H);
ext_int_edge(2, H_TO_L);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
disable_interrupts(INT_LOWVOLT);
disable_interrupts(INT_TIMER1);
Dr Suleyman CANAN
PostPosted: Mon Sep 15, 2025 9:46 am     Reply with quote
sigh...not a complete program..
after you enable the interrupts.... it does nothing ? As coded, it'd go to 'sleep'.
You really need to post the complete program. we can't see what's going on with just 'bits and pieces'.
BTW need to add 'errors' to the #use RS232(..... errors..... )
scanan
PostPosted: Tue Sep 16, 2025 10:47 am     Reply with quote
here is a test program
compiler version 5.115
#include <18F65K40.h>
#FUSES NOWDT
#FUSES EBTR,EBTRB
#ID CHECKSUM
#case
#use delay(clock=64000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use fast_io(F)
#use fast_io(G)
#use fast_io(H)
#int_EXT1 //Button 1
void EXT_isr1(void) {
#int_EXT2 // button 2
void EXT_isr2(void) {
#int_TIMER0
void TIMER0_isr(void) {
static unsigned int16 n;
n++;
if(n>500){
output_toggle(PIN_A5);
n=0;
set_timer0(65285);
clear_interrupt(INT_TIMER0);
//! output_a(0b00000000);
//! output_b(0b00000000);
//! output_c(0b00000000);
//! output_d(0b00000000);
//! output_e(0b00000000);
//! output_f(0b00000000);
//! output_g(0b00000000);
//! output_h(0b00000000);
set_tris_a(0b11001111);
set_tris_b(0b10101110);
set_tris_c(0b10010000);
set_tris_d(0b00000100);
set_tris_e(0b11111111);
set_tris_f(0b11111111);
set_tris_g(0b11011111);
set_tris_h(0b00000011);
setup_wdt(WDT_OFF);
setup_adc(ADC_OFF);
setup_timer_0(T0_INTERNAL | T0_16_BIT | T0_DIV_4 );
setup_vref(FALSE);
//setup_oscillator(OSC_HFINTRC_64MHZ );
loop:
printf("hello ccs info forum\r\n");
goto loop;
I think I localized the problem when I disable TIMER0 everything works fine I get the printf clearly
but when I enable TIMER0
get garbage from rs232 port ..
did I do something wrong ?
Dr Suleyman CANAN
gaugeguy
PostPosted: Tue Sep 16, 2025 12:08 pm     Reply with quote
You are using a software UART routine so anything else going on will disrupt the timing.
scanan
PostPosted: Tue Sep 16, 2025 12:37 pm     Reply with quote
Please pin point the issue
Dr Suleyman CANAN
Page 2 of 3
