rs232 prints rubish
Goto page Previous  1, 2
scanan
PostPosted: Fri May 09, 2025 7:53 am     Reply with quote
temtronic wrote:
curious....
you've made several changes so could you please post the program and the printout ?
thanks
set_tris_a(0b00001000); //0x08
set_tris_b(0b11000100); //0xC4
set_tris_c(0b10100000); //0xA0
set_tris_d(0b00000000); //0x00
set_tris_e(0b00001000); //0x08
TX and RX are situated at pinc6 and c7 respectively
#use delay(clock=64000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
void version(void)
//-- firmware version
printf("\r\nTelemmote Receiver\r\n");
printf("TLM-02\r\n");
printf("Firmware v1.00\r\n");
printf("Compiled on \r\n");
printf(__DATE__);
printf("\r\n");
printf(__TIME__);
printf("\r\n");
should work flawlesly but result is
U V W $ Y YZ Y C irmware v1.00
Compiled on
07-May-25
11:20:24
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Fri May 09, 2025 9:13 am     Reply with quote
Hmm....you don't have the 'delay_ms(250);' just before the first print.
allenhuffman
PostPosted: Fri May 09, 2025 9:54 am     Reply with quote
One of the four PIC24 boards I maintain had an issue with unreliable serial output, and it ended up being caused by a timer ISR. I had to move it to a different timer and then the output worked fine.
I have no idea why that was, but left myself a TODO in the comments to look into it... some day.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
PostPosted: Fri May 09, 2025 11:38 am     Reply with quote
Show your fuses.
How is the 64MHz generated????.
Show how the main code starts, and calls 'version'.
Did PUT make no difference at all?.
PostPosted: Fri May 09, 2025 2:44 pm     Reply with quote
we really need to see the complete program !
PostPosted: Fri May 09, 2025 11:54 pm     Reply with quote
More to the point, you really need to generate a basic test program that just
shows the issue. Simple main, and the code to call the version display.
Doing this then proves there isn't something hidden causing the issue as
Allen describes. Then post this.
Page 2 of 2
