allenhuffman
Joined: 17 Jun 2019 Posts: 621 Location: Des Moines, Iowa, USA
SOLVED: Getting UART over ICSP pins on PIC24EP256GP202 |
Posted: Wed Jul 12, 2023 8:15 am |
Awhile ago, I posted a topic where I was trying to get a serial port working on a device:
http://www.ccsinfo.com/forum/viewtopic.php?t=59501&highlight=
I am now trying to do the same thing (for the same reason -- a board without UART pins, hijacking the ICSP pins to use for printfs).
On this hardware, the compiler says I cannot use these pins:
Code: | // Use ICSP port pins 5 (B1) as UART RX, and pin 4 (B0) as UART TX
// ICSP Port: 5 4 3 2 1
// B1 B0 G 3V
#pin_select U1TX=PIN_B0
#pin_select U1RX=PIN_B1
#use rs232 (BAUD=115200, UART1) |
I started by copying this over from the working board (different PIC24) and now am trying to figure out if I can even get this going.
I'd be fine even with software bitbanger ports, but I have not used those (assuming they are in CCS somewhere).
Tips? _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
Last edited by allenhuffman on Wed Jul 12, 2023 10:06 am; edited 1 time in total |
allenhuffman
Posted: Wed Jul 12, 2023 8:49 am |
I was able to get software serial working:
Code: | #use rs232 (BAUD=115200, FORCE_SW, XMIT=PIN_B0, RCV=PIN_B1) |
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
gaugeguy
Posted: Wed Jul 12, 2023 9:16 am |
According to the data sheet RB0 is RPI so PPS input only. |
allenhuffman
Posted: Wed Jul 12, 2023 10:03 am |
gaugeguy wrote: | According to the data sheet RB0 is RPI so PPS input only. |
Ah ... "/RPI32" -- I must have thought 132 not I-32. Well, then, I guess I'm out of luck with this part.
When I use the ICD80 debugger console, it tends to lock up and scramble data pretty easily.
When using serial, it ran much longer (I got 15,000 lines before it crashed with out of memory). But, too much printing and it also locks up even in Serial Port mode.
I had hoped UART would be faster but I don't have any other free pins to try to hijack.
Thanks for pointing that out. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
jeremiah
Posted: Wed Jul 12, 2023 6:56 pm |
allenhuffman wrote: | I was able to get software serial working:
Because it is a software UART, you should also add DISABLE_INTS to your options to avoid garbling of the messages |
