SOLVED: Getting UART over ICSP pins on PIC24EP256GP202
allenhuffman
PostPosted: Wed Jul 12, 2023 8:15 am     Reply with quote
Awhile ago, I posted a topic where I was trying to get a serial port working on a device:
http://www.ccsinfo.com/forum/viewtopic.php?t=59501&highlight=
I am now trying to do the same thing (for the same reason -- a board without UART pins, hijacking the ICSP pins to use for printfs).
On this hardware, the compiler says I cannot use these pins:
// Use ICSP port pins 5 (B1) as UART RX, and pin 4 (B0) as UART TX
// ICSP Port: 5  4  3  2  1
//            B1 B0 G  3V
#pin_select U1TX=PIN_B0
#pin_select U1RX=PIN_B1
#use rs232 (BAUD=115200, UART1)
I started by copying this over from the working board (different PIC24) and now am trying to figure out if I can even get this going.
I'd be fine even with software bitbanger ports, but I have not used those (assuming they are in CCS somewhere).
Tips?
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
allenhuffman
PostPosted: Wed Jul 12, 2023 8:49 am     Reply with quote
I was able to get software serial working:
#use rs232 (BAUD=115200, FORCE_SW, XMIT=PIN_B0, RCV=PIN_B1)
gaugeguy
PostPosted: Wed Jul 12, 2023 9:16 am     Reply with quote
According to the data sheet RB0 is RPI so PPS input only.
allenhuffman
PostPosted: Wed Jul 12, 2023 10:03 am     Reply with quote
Ah ... "/RPI32" -- I must have thought 132 not I-32. Well, then, I guess I'm out of luck with this part.
When I use the ICD80 debugger console, it tends to lock up and scramble data pretty easily.
When using serial, it ran much longer (I got 15,000 lines before it crashed with out of memory). But, too much printing and it also locks up even in Serial Port mode.
I had hoped UART would be faster but I don't have any other free pins to try to hijack.
Thanks for pointing that out.
jeremiah
PostPosted: Wed Jul 12, 2023 6:56 pm     Reply with quote
Because it is a software UART, you should also add DISABLE_INTS to your options to avoid garbling of the messages
