allenhuffman
Joined: 17 Jun 2019 Posts: 645 Location: Des Moines, Iowa, USA
| [SOLVED]#use rs232(ICD,...) debugger printfs on 24EP256GP202 |
Posted: Tue Aug 20, 2019 10:24 am |
I am now trying to get debug printfs working on another board. This one uses the PIC24EP256GP202.
Using the same #use rs232(ICD) that works on another board (and the Explorer), I get no output. (Serial I/O Monitor opens, but nothing happens.) I expect it is a config difference on this board.
As far as I can tell from the schematics, the ICSP is wired to:
1 - MCLR
2 - 3V
3 - GND
4 - PGED1 (RB3)
5 - PGEC1 (RB2)
I tried
#use rs232(ICD,XMIT=PIN_B2,RCV=PIN_B3)
and
#use rs232(ICD,XMIT=PIN_B3,RCV=PIN_B2)
...with no results. The board that works is using B0 and B1, and it works without specifying XMIT or RCV.
Are there other things that might need to be done to get debug output running?
Thanks! _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
Last edited by allenhuffman on Tue Aug 20, 2019 11:28 am; edited 1 time in total |
Posted: Tue Aug 20, 2019 11:22 am |
What is the other board ? If it's manufactured, tell us the manufacturer
and the name, model or part number. |
allenhuffman
Posted: Tue Aug 20, 2019 11:26 am |
| PCM programmer wrote: | What is the other board ? If it's manufactured, tell us the manufacturer
Designed by us, manufactured for us
Turns out, there was a typo in the schematic. Once I figured that out, and confirmed with the hardware group, I was able to get it working:
1 - MCLR
2 - 3V
3 - GND
4 - PGED3 (RB0)
5 - PGEC3 (RB1)
#use rs232(ICD,XMIT=PIN_B0,RCV=PIN_B1)
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
niels_J
