[SOLVED]#use rs232(ICD,...) debugger printfs on 24EP256GP202
allenhuffman
PostPosted: Tue Aug 20, 2019 10:24 am     Reply with quote
I am now trying to get debug printfs working on another board. This one uses the PIC24EP256GP202.
Using the same #use rs232(ICD) that works on another board (and the Explorer), I get no output. (Serial I/O Monitor opens, but nothing happens.) I expect it is a config difference on this board.
As far as I can tell from the schematics, the ICSP is wired to:
1 - MCLR
2 - 3V
3 - GND
4 - PGED1 (RB3)
5 - PGEC1 (RB2)
I tried
#use rs232(ICD,XMIT=PIN_B2,RCV=PIN_B3)
and
#use rs232(ICD,XMIT=PIN_B3,RCV=PIN_B2)
...with no results. The board that works is using B0 and B1, and it works without specifying XMIT or RCV.
Are there other things that might need to be done to get debug output running?
Thanks!
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
PostPosted: Tue Aug 20, 2019 11:22 am     Reply with quote
What is the other board ? If it's manufactured, tell us the manufacturer
and the name, model or part number.
allenhuffman
PostPosted: Tue Aug 20, 2019 11:26 am     Reply with quote
Designed by us, manufactured for us Smile
Turns out, there was a typo in the schematic. Once I figured that out, and confirmed with the hardware group, I was able to get it working:
1 - MCLR
2 - 3V
3 - GND
4 - PGED3 (RB0)
5 - PGEC3 (RB1)
#use rs232(ICD,XMIT=PIN_B0,RCV=PIN_B1)
Thanks!
niels_J
PostPosted: Tue Mar 10, 2020 10:06 am     Reply with quote
Some more gotchas:
I carefully read this and other topics like:
http://www.ccsinfo.com/forum/viewtopic.php?p=225091
https://www.ccsinfo.com/forum/viewtopic.php?t=56988
http://www.ccsinfo.com/forum/viewtopic.php?p=225064
https://www.youtube.com/watch?v=EnSazS39MeA
http://www.ccsinfo.com/forum/viewtopic.php?p=143276
https://www.ccsinfo.com/forum/viewtopic.php?p=223256
but still couldn't get it working.
What I have found out:
1. ccsloader works as telnet server. I had the telnetservice in windows running, which interfered. After disabling this service the siow window poped up without errors but there were no data communication.
2. My device is PIC16F18855 with pin-select. I added:
#pin_select NULL=PIN_B6
#pin_select NULL=PIN_B7
#use RS232(ICD, DISABLE_INTS, xmit=PIN_B7, rcv=PIN_B6)
Explicit xmit and rcv seems to be necessary despite being the default.
Now data from the device is showing as expected except for frequent data errors. This must be due to timing mismatch between device and ICD. I use the internal clock which is not very accurate.
I hope this will help other which are struggling with this problem.
Using a hardware port is far more useful for debugging. Connect it to an ftdi usb/serial converter. These devices support non-standard fine-grained baud rates which can be used to compensate for an inaccurate internal clock.
