Declaring Bit
Zezem
Declaring Bit
PostPosted: Thu Mar 02, 2017 11:37 am     Reply with quote
ok I'm having trouble compiling this code from my global.h file
extern int8 flags;
#BIT USB_BAD_BYTE_COUNT = flags.0 //error here
#BIT USB_BAD_CHECKSUM = flags.1 //error here
#BIT USB_WW_BUSY = flags.2 //error here
#BIT SERIAL_PROGRAM_INITIATED = flags.5 //error here
#BIT USB_BAD_COMMAND = flags.6 //error here
#BIT RUN_WW = flags.7 //error here
#byte INTCON          =0xFF2
#byte PIR1         = 0xF9E
#byte TMR0H         = 0xFD7
#byte TMR0L         = 0xFD6
#byte T0CON         = 0xFD5
#bit  TMR0IF              = INTCON.2  //error here
#byte TMR1H         = 0xFCF
#byte TMR1L         = 0xFCE
#byte T1CON         = 0xFCD
#bit TMR1IF              = PIR1.0  //error here
#byte ADCON0              = 0xFC2
#byte ADCON1              = 0xFC1
#byte ADCON2              = 0xFC0
#byte ADRESH              = 0xFC4
#byte ADRESL              = 0xFC3
PostPosted: Thu Mar 02, 2017 4:04 pm     Reply with quote
I think 'extern' only works if you enable Multiple Compilation Units in the
CCS IDE. I don't have the IDE version of the compiler, so I can't test it
for you. Do you have MCU's enabled ?
Your other errors can be fixed by extracting the bit address from the
compiler's database file, by using getenv(). Example:
#bit TMR0IF = getenv("BIT:TMR0IF")
#bit TMR1IF = getenv("BIT:TMR1IF")
