rajeshkhan808
| Why are all my pins high with set_tris_a(0xFF) -PIC 16f877A |
Posted: Thu Aug 30, 2012 2:07 am |
When I do set_tris_a(0xFF) for setting all the pins of port A on my PIC16F877A as input. They are all high. I thought they are still in analog mode.So I did the following
setup_adc( ADC_OFF );
setup_adc_ports(NO_ANALOGS);
set_tris_a(0xFF); |
However they are still high. Why is that ?
Last edited by rajeshkhan808 on Thu Aug 30, 2012 2:30 am; edited 4 times in total |
Posted: Thu Aug 30, 2012 2:21 am |
What PIC....
Normally:
but the syntax does change between chips.
rajeshkhan808
Posted: Thu Aug 30, 2012 2:22 am |
| Hi , thanks for the reply just edited the question. I am using PIC16F877A |
Posted: Thu Aug 30, 2012 2:42 am |
Obvious thing is something external pulling them up....
Remember that a 'input' pin, has a very high impedance, and will sit for minutes, at the voltage it was last 'at', if nothing else is connected. It is up to whatever you connect externally to pull them to the required level.
Now, on some of the pins (A4, A5), you have the comparator outputs, so this needs to be disabled (setup_comparator(NC_NC_NC_NC)).
Mike Walne
Posted: Thu Aug 30, 2012 3:03 pm |
If you are still really stuck, post SHORT complete compilable code which shows the problem.
Also quote version No. and see forum guidelines.
Mike |
benoitstjean
Joined: 30 Oct 2007 Posts: 595 Location: Ottawa, Ontario, Canada
Posted: Fri Aug 31, 2012 6:07 am |
| Put some 4.7K resistors on each pin to GND. That'll solve the problem. If you don't, then the pins somewhat act as "antennas" and will react to whatever it "captures" so just rubbing your finger on a pin will make it change state. If you connect a 4.7K to GND, then the inputs are pulled low and will remain low until you send it a high level. |
rajeshkhan808
| SOLVED |
Posted: Fri Aug 31, 2012 6:42 am |
@benoitstjean
Thanks that solved the problem |
