Why are all my pins high with set_tris_a(0xFF) -PIC 16f877A
rajeshkhan808
PostPosted: Thu Aug 30, 2012 2:07 am     Reply with quote
When I do set_tris_a(0xFF) for setting all the pins of port A on my PIC16F877A as input. They are all high. I thought they are still in analog mode.So I did the following
 setup_adc( ADC_OFF );
setup_adc_ports(NO_ANALOGS);
   set_tris_a(0xFF);
However they are still high. Why is that ?
PostPosted: Thu Aug 30, 2012 2:21 am     Reply with quote
What PIC....
Normally:
but the syntax does change between chips.
rajeshkhan808
PostPosted: Thu Aug 30, 2012 2:22 am     Reply with quote
Hi , thanks for the reply just edited the question. I am using PIC16F877A
PostPosted: Thu Aug 30, 2012 2:42 am     Reply with quote
Obvious thing is something external pulling them up....
Remember that a 'input' pin, has a very high impedance, and will sit for minutes, at the voltage it was last 'at', if nothing else is connected. It is up to whatever you connect externally to pull them to the required level.
Now, on some of the pins (A4, A5), you have the comparator outputs, so this needs to be disabled (setup_comparator(NC_NC_NC_NC)).
Mike Walne
PostPosted: Thu Aug 30, 2012 3:03 pm     Reply with quote
If you are still really stuck, post SHORT complete compilable code which shows the problem.
Also quote version No. and see forum guidelines.
Mike
benoitstjean
PostPosted: Fri Aug 31, 2012 6:07 am     Reply with quote
Put some 4.7K resistors on each pin to GND. That'll solve the problem. If you don't, then the pins somewhat act as "antennas" and will react to whatever it "captures" so just rubbing your finger on a pin will make it change state. If you connect a 4.7K to GND, then the inputs are pulled low and will remain low until you send it a high level.
rajeshkhan808
SOLVED
PostPosted: Fri Aug 31, 2012 6:42 am     Reply with quote
@benoitstjean
Thanks that solved the problem
