How to store float value in EEPROM
Sid2286
PostPosted: Tue Aug 16, 2011 12:32 am     Reply with quote
I'm in a problem don't understand how to do it!
1. I have a variable type float where I cannot use '%' sign as an operator.
2. using write_eeprom(adress,value) value is int type so I guess cannot pass float.
how do i do it?
My code is something like this:
                       printf(lcd_putc," \fEnter\nCalibration value.");
                       cali = read_button();     // cali = float
                       printf(lcd_putc," \f Present\n Value");
                       f=read_button();      // f= float
                       cali=cali/f;
                       printf(lcd_putc,"\f Cal.\nSaved");
And for storing the value i'm using something like:
                    temEE=cali/256;
                    write_eeprom(10,temEE);
                    temEE=cali%256;        // Error cannot use % for float
                    write_eeprom(11,temEE);
Please help, I thought of using an int pointer and doing it, but thats way too lengthy way to do it, if any one has a better way please help!
thanks,
Sid
asmallri
Re: How to store float value in EEPROM
PostPosted: Tue Aug 16, 2011 3:17 am     Reply with quote
Sid2286 wrote:
how do i do it?
                       cali=cali/f;
                    temEE=cali/256;
thanks,
Sid
         BYTE i, offset, *ptr;
         offset = 10;  // or whatever the offset is meant to be
         ptr = (BYTE*)&cali;
         for (i=0, i < sizeof(cali),i++)
              write_eeprom(offset++,*ptr++);
Regards, Andrew
SherpaDoug
PostPosted: Tue Aug 16, 2011 5:45 am     Reply with quote
Look at the make8() and make32() functions. You store data to EEPROM as bytes. Break larger structures (like floats) into to bytes and put the bytes into EEPROM.
PostPosted: Tue Aug 16, 2011 12:59 pm     Reply with quote
CCS has a driver file with routines to store floats and ints in eeprom:
c:\program files\picc\drivers\internal_eeprom.c
Just #include it in your program and call the appropriate routines.
There is also another file with routines for external eeprom.
