Sid2286
How to store float value in EEPROM |
Posted: Tue Aug 16, 2011 12:32 am |
I'm in a problem don't understand how to do it!
1. I have a variable type float where I cannot use '%' sign as an operator.
2. using write_eeprom(adress,value) value is int type so I guess cannot pass float.
how do i do it?
My code is something like this:
printf(lcd_putc," \fEnter\nCalibration value.");
cali = read_button(); // cali = float
printf(lcd_putc," \f Present\n Value");
f=read_button(); // f= float
cali=cali/f;
printf(lcd_putc,"\f Cal.\nSaved");
And for storing the value i'm using something like:
temEE=cali/256;
write_eeprom(10,temEE);
temEE=cali%256; // Error cannot use % for float
write_eeprom(11,temEE);
Please help, I thought of using an int pointer and doing it, but thats way too lengthy way to do it, if any one has a better way please help!
thanks,
Sid |
asmallri
Joined: 12 Aug 2004 Posts: 1658 Location: Perth, Australia
Re: How to store float value in EEPROM |
Posted: Tue Aug 16, 2011 3:17 am |
Sid2286 wrote: | Hi,
how do i do it?
cali=cali/f;
temEE=cali/256;
thanks,
Sid |
BYTE i, offset, *ptr;
offset = 10; // or whatever the offset is meant to be
ptr = (BYTE*)&cali;
for (i=0, i < sizeof(cali),i++)
write_eeprom(offset++,*ptr++);
_________________ Regards, Andrew
SherpaDoug
Posted: Tue Aug 16, 2011 5:45 am |
Look at the make8() and make32() functions. You store data to EEPROM as bytes. Break larger structures (like floats) into to bytes and put the bytes into EEPROM. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Tue Aug 16, 2011 12:59 pm |
CCS has a driver file with routines to store floats and ints in eeprom:
Quote: |
c:\program files\picc\drivers\internal_eeprom.c
Just #include it in your program and call the appropriate routines.
There is also another file with routines for external eeprom. |
