Error: Previous identifier must be a pointer
pyu
PostPosted: Thu Oct 08, 2009 1:54 pm     Reply with quote
Hi.
I have declared
signed int16 Temp[4];
Then,
 for (numRoms=1;numRoms<=4;numRoms++)
            if (Send_MatchRom())
               write_byte(0xBE); // Read scratch pad command
               dowcrc = 0;       // Reset the crc to start a new calculation
               for (i=0;i<=7;i++)
                   scratch[i] = read_byte();
                   ow_crc(scratch[i]);     // Accumulate the crc
               scratch[8] = read_byte();   // Received crc byte
               ow_reset();
               // If calculated crc from incoming bytes equal to crc byte
               // then data is valid. Calculate and output temperature.
               if (scratch[8] == dowcrc)
               temp = make16(scratch[1],scratch[0]);
               result = (float) temp / 16.0; //0.1 deg C resolution
               //printf(lcd_putc,"\fT%i= %3.1f \uC", numRoms, result);
               Temp[numRoms] = result;
               printf(lcd_putc,"\fData error.");       // There was an error in the data
I want to assign a value to Temp[0], Temp[1], Temp[2], Temp[3],
and then to print this value to LCD.
printf(lcd_putc, "\nENG:\%3.1fC \EXT:%2.1fC", Temp[0], Temp[1]);
I get 2 errors:
** Error 116 "C:\Car_LCD\CarLCD.c" Line 570(62,63): Printf variable count (%) does not match actual count ::
*** Error 66 "C:\Car_LCD\CarLCD.c" Line 638(6,13): Previous identifier must be a pointer
First error I get it from this line:
The second error:
What is wrong in my code?
PostPosted: Thu Oct 08, 2009 2:14 pm     Reply with quote
Look at your code. You have an array of 'signed int' values, but you're
trying to display them as floating point numbers.
You didn't post the declarations for 'numRoms' or 'result'.
It's easier to give you an answer if you post a real test program,
with all varible declarations, and that is compilable. Also post
your PIC and compiler version.
Wayne_
PostPosted: Fri Oct 09, 2009 1:59 am     Reply with quote
Surely the problem lies with the fact the '\' is an escape char i.e
\% will escape the %
If your intention is to disply a '\' then you need to use 2 off them but I suspect you have just made a mistake! :-
printf(lcd_putc, "\nENG: %3.1fC EXT:%2.1fC", Temp[0], Temp[1]);
But PCM programmer has a valid point.
pyu
PostPosted: Fri Oct 09, 2009 2:37 am     Reply with quote
I had corrected the first error.
int8 numROMs;
float result=0;
Here is my entire project, after build, I get that single error (Previous identifier must be a pointer):
http://cid-e0cf397449e54fc9.skydrive.live.com/self.aspx/Public/PicKit2/CarLCD/CarLCD.zip
Wayne_
PostPosted: Fri Oct 09, 2009 2:44 am     Reply with quote
An array has a zero based index in C
So
gives you
Temp[0] to Temp[3]
you either need to change your for loop
for (numRoms=0;numRoms<=3;numRoms++)
or change the assignment.
Temp[numRoms - 1] = result;
I don't think this is your problem though.
post more info, including definitions of vars used.
pyu
PostPosted: Fri Oct 09, 2009 2:53 am     Reply with quote
I tried
Temp[numROMs - 1] = result;
, but no succes.
In previous post, I added a zip with my project.
Here is a sample code:
int8 numROMs;
float Temp[4];
void Read_DS_Temperature(void)
   int8 i;
   signed int16 temperature;
   int8 scratch[9];
   signed int16 temp;
   float result=0;
   if (!ow_reset())     // If a device is present
         write_byte(0xCC); // Skip Rom command
         write_byte(0x44); // Temperature convert command
         output_float(DQ);
         delay_ms(750);    // Max. conv. time is 750mS for 12 bit
         ow_reset();
         // Now get the device raw temperature data using Match ROM with the
         // addresses obtained with FindDevices().  Scale to deg. C, scaling is
         // 0.0625 (1/16) deg. C/bit with default 12 bit res. Could reduce res.
         // and therefore shorten conversion time if necessary.
         // Output the temperatures in whole degrees, apply rounding by adding
         // half denom.
         for (numROMs=1;numROMs<=4;numROMs++)
               for (i=0;i<=7;i++)
               ow_reset();
         printf(lcd_putc,"\fSenzor Error!");
then:
while(1){
Wayne_
PostPosted: Fri Oct 09, 2009 3:33 am     Reply with quote
So which error are you still getting and what is the line ? please show code surrounding this and any definitions as well.
pyu
PostPosted: Fri Oct 09, 2009 3:41 am     Reply with quote
Error:
Line:
main.c:
#include <16F887.H>
#include <math.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,NOBROWNOUT,NOWRT
#use delay(clock = 20000000)
//#device adc=10  *=16      - ???
#define DQ PIN_E0 // One Wire Bus pin assignment
#define RTC_SDA  PIN_C4
#define RTC_SCL  PIN_C3
#use I2C(MULTI_MASTER,sda=RTC_SDA, scl=RTC_SCL)
#include "Flex_LCD420.c"
#include "CarLCD.h"
#include "CarLCD.c"
    lcd_init();
   output_float(DQ);       // Set as input. 4k7 pullup on bus.
   FindDevices();
   ow_reset();
      DisplayInformations();
CarLCD.h:
// Global variables
int8 Rom_Bit[8]; // Rom_Bit bit
int8 lastDiscrep = 0;
short doneFlag = 0;
int8 FoundROM[7][8]; // Table of found ROM codes, 8 bytes for each
int8 numROMs;
int8 dowcrc; // crc is accumulated in this variable
// crc lookup table
int8 const dscrc_table[] = {
0,94,188,226,97,63,221,131,194,156,126,32,163,253,31,65,
157,195,33,127,252,162,64,30,95,1,227,189,62,96,130,220,
35,125,159,193,66,28,254,160,225,191,93,3,128,222,60,98,
190,224,2,92,223,129,99,61,124,34,192,158,29,67,161,255,
70,24,250,164,39,121,155,197,132,218,56,102,229,187,89,7,
219,133,103,57,186,228,6,88,25,71,165,251,120,38,196,154,
101,59,217,135,4,90,184,230,167,249,27,69,198,152,122,36,
248,166,68,26,153,199,37,123,58,100,134,216,91,5,231,185,
140,210,48,110,237,179,81,15,78,16,242,172,47,113,147,205,
17,79,173,243,112,46,204,146,211,141,111,49,178,236,14,80,
175,241,19,77,206,144,114,44,109,51,209,143,12,82,176,238,
50,108,142,208,83,13,239,177,240,174,76,18,145,207,45,115,
202,148,118,40,171,245,23,73,8,86,180,234,105,55,213,139,
87,9,235,181,54,104,138,212,149,203,41,119,244,170,72,22,
233,183,85,11,136,214,52,106,43,117,151,201,74,20,246,168,
116,42,200,150,21,75,169,247,182,232,10,84,215,137,107,53
// Returns 0 for one wire device presence, 1 for none
int8 ow_reset(void);
// Read bit on one wire bus
int8 read_bit(void);
void write_bit(int8 bitval) ;
int8 read_byte(void) ;
void write_byte(int8 val) ;
// One wire crc
int8 ow_crc(int8 x) ;
// Searches for the next device on the one wire bus. If there are no more
// devices on the bus then false is returned.
int8 Next(void);
// Resets current state of a ROM search and calls Next to find the first device
// on the one wire bus.
int8 First(void);
void FindDevices(void);
// Sends Match ROM command to bus then device address
int8 Send_MatchRom(void);
float Temp[4];
CarLCD.c:
//DS18B20
int8 ow_reset(void)
   int8 presence;
   output_low(DQ);
   delay_us(488);          // Min. 480uS
   output_float(DQ);
   delay_us(72);           // Takes 15 to 60uS for devices to respond
   presence = input(DQ);
   delay_us(424);          // Wait for end of timeslot
   //printf(lcd_putc, "\fPresence= %i", presence);
//delay_ms(500);
   return(presence);
int8 read_bit(void)
   output_low(DQ);
   delay_us(1);         // 1uS min. Original code relied on 8051 being slow
   output_float(DQ);
   delay_us(20);        // Wait at least 15mS from start of time slot
   return(input(DQ));   // Delay to finish time slot (total 60 to 120uS)
} // must be done next.
   output_low(DQ);
   if(bitval == 1) {
      output_float(DQ);
   delay_us(105);       // Wait for end of timeslot
   output_float(DQ);
   int8 i;
   int8 val = 0;
   for(i=0;i<8;i++)
      if(read_bit()) val |= (0x01 << i);
      delay_us(120);  // To finish time slot
   return val;
   int8 i;
   int8 temp;
   for (i=0;i<8;i++)
      temp = val >> i;
      temp &= 0x01;
      write_bit(temp);
   delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
   dowcrc = dscrc_table[dowcrc^x];
   return dowcrc;
int8 Next(void)
   int8 m = 1;             // ROM Bit index
   int8 n = 0;             // ROM Byte index
   int8 k = 1;             // Bit mask
   int8 x = 0;
   int8 discrepMarker = 0;
   int8 g;                 // Output bit
   int8 nxt;               // Return value
   short flag;
   nxt = FALSE;            // Reset next flag to false
   dowcrc = 0;             // Reset the dowcrc
   flag = ow_reset();
   if (flag||doneFlag)     // If no parts return false
      lastDiscrep = 0;     // Reset the search
      return FALSE;
   write_byte(0xF0);       // Send SearchROM command
   do
      x = 0;
      if (read_bit() == 1)
      x = 2;
      delay_us(120);
      x |= 1;   // And it's complement
      if (x == 3)                   // There are no devices on the one wire bus
         if (x > 0)                 // All devices coupled have 0 or 1
            g = x >> 1;             // Bit write value for search
         // If this discrepancy is before the last discrepancy on a previous
         // Next then pick the same as last time.
            if (m < lastDiscrep)
               g = ((Rom_Bit[n] & k) > 0);
            // If equal to last pick 1
               g = (m == lastDiscrep);  // If not then pick 0
               // If 0 was picked then record position with mask k
               if (g == 0) discrepMarker = m;
         // Isolate bit in Rom_Bit[n] with mask k
         if (g == 1)
         Rom_Bit[n] |= k;
         Rom_Bit[n] &= ~k;
         write_bit(g);  // ROM search write
         m++;           // Increment bit counter m
         k = k << 1;    // and shift the bit mask k
         // If the mask is 0 then go to new ROM
         if (k == 0)
         {  // Byte n and reset mask
            ow_crc(Rom_Bit[n]);      // Accumulate the crc
            n++;
            k++;
   } while (n < 8);  // Loop through until through all ROM bytes 0-7
   if (m < (65||dowcrc))   // If search was unsuccessful then
      lastDiscrep = 0;     // reset the last Discrepancy to zero
   else  // Search was successful, so set lastDiscrep, lastOne, nxt
      lastDiscrep = discrepMarker;
      doneFlag = (lastDiscrep == 0);
      nxt = TRUE; // Indicates search not yet complete, more parts remain
   return nxt;
int8 First(void)
   lastDiscrep = 0;
   doneFlag = FALSE;
   return Next(); // Call Next and return it's return value;
   int8 m;
   if(!ow_reset())
      if(First())    // Begins when at least one part found
         numROMs = 0;
         do
            numROMs++;
            for (m=0;m<8;m++)
               FoundROM[numROMs][m] = Rom_Bit[m];   // Identifies ROM no. on device
            //printf("Device No.%u address ",numROMs);
         //printf(lcd_putc,"%u  no dev=",numROMs);
         //delay_ms(1000);
         printf(lcd_putc, "\f%X%X%X%X%X%X%X%X",
         FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5], \
         FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2], \
         FoundROM[numROMs][1],FoundROM[numROMs][0]);
            //printf("%X%X%X%X%X%X%X%X\n\r",
            //FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5],
            //FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2],
            //FoundROM[numROMs][1],FoundROM[numROMs][0]);
         } while (Next() && (numROMs<10));   // Continues until no additional
                                             // devices found.
            printf(lcd_putc, "\fno ROM found");
         //delay_ms(500);
            printf(lcd_putc, "\fno ROM found2");
         //delay_ms(500);
   //putc('\n'); putc('\r');
   int8 i;
   if (ow_reset()) return FALSE;          // 0 if device present
   write_byte(0x55);                      // Match ROM
   for (i=0;i<8;i++)
      write_byte(FoundRom[numROMs][i]);   // Send ROM code
   return TRUE;
void DisplayInformations(void)
         Read_DS_Temperature();
   int8 i;
   int8 scratch[9];
   signed int16 temp;
   float result=0;
         output_float(DQ);
         ow_reset();
         // half denom.
               for (i=0;i<=7;i++)
               ow_reset();
PostPosted: Fri Oct 09, 2009 4:11 am     Reply with quote
It's a simple matter of code confusion.
On one hand you're utilizing the default case insensitive behaviour of CCS C (you get many errors, when activating #case for you code), on the other hand you have this:
int16 temp;
// and at another place
float Temp[4];
Decide, if you are going for #case or #nocase and correct your code respectively.
pyu
PostPosted: Mon Oct 12, 2009 3:55 am     Reply with quote
Thanks FvM.
It's working now!
