pyu
Error: Previous identifier must be a pointer |
Posted: Thu Oct 08, 2009 1:54 pm |
Hi.
I have declared
Code: | signed int16 Temp[4]; |
Then,
Code: | for (numRoms=1;numRoms<=4;numRoms++)
if (Send_MatchRom())
write_byte(0xBE); // Read scratch pad command
dowcrc = 0; // Reset the crc to start a new calculation
for (i=0;i<=7;i++)
scratch[i] = read_byte();
ow_crc(scratch[i]); // Accumulate the crc
scratch[8] = read_byte(); // Received crc byte
ow_reset();
// If calculated crc from incoming bytes equal to crc byte
// then data is valid. Calculate and output temperature.
if (scratch[8] == dowcrc)
temp = make16(scratch[1],scratch[0]);
result = (float) temp / 16.0; //0.1 deg C resolution
//printf(lcd_putc,"\fT%i= %3.1f \uC", numRoms, result);
Temp[numRoms] = result;
printf(lcd_putc,"\fData error."); // There was an error in the data
I want to assign a value to Temp[0], Temp[1], Temp[2], Temp[3],
and then to print this value to LCD.
Code: | printf(lcd_putc, "\nENG:\%3.1fC \EXT:%2.1fC", Temp[0], Temp[1]); |
I get 2 errors:
Quote: | ** Error 116 "C:\Car_LCD\CarLCD.c" Line 570(62,63): Printf variable count (%) does not match actual count ::
*** Error 66 "C:\Car_LCD\CarLCD.c" Line 638(6,13): Previous identifier must be a pointer |
First error I get it from this line:
The second error:
Code: | Temp[numRoms] = result; |
What is wrong in my code? |
Posted: Thu Oct 08, 2009 2:14 pm |
Look at your code. You have an array of 'signed int' values, but you're
trying to display them as floating point numbers.
Quote: | Temp[numRoms] = result; |
You didn't post the declarations for 'numRoms' or 'result'.
It's easier to give you an answer if you post a real test program,
with all varible declarations, and that is compilable. Also post
your PIC and compiler version. |
Wayne_
Posted: Fri Oct 09, 2009 1:59 am |
Surely the problem lies with the fact the '\' is an escape char i.e
\% will escape the %
If your intention is to disply a '\' then you need to use 2 off them but I suspect you have just made a mistake! :-
printf(lcd_putc, "\nENG: %3.1fC EXT:%2.1fC", Temp[0], Temp[1]);
But PCM programmer has a valid point. |
pyu
Wayne_
Posted: Fri Oct 09, 2009 2:44 am |
An array has a zero based index in C
So
gives you
Temp[0] to Temp[3]
you either need to change your for loop
for (numRoms=0;numRoms<=3;numRoms++)
or change the assignment.
Temp[numRoms - 1] = result;
I don't think this is your problem though.
post more info, including definitions of vars used. |
pyu
Posted: Fri Oct 09, 2009 2:53 am |
Wayne_ wrote: | An array has a zero based index in C
I tried Code: | Temp[numROMs - 1] = result; | , but no succes.
In previous post, I added a zip with my project.
Here is a sample code:
int8 numROMs;
float Temp[4];
void Read_DS_Temperature(void)
int8 i;
signed int16 temperature;
int8 scratch[9];
signed int16 temp;
float result=0;
if (!ow_reset()) // If a device is present
write_byte(0xCC); // Skip Rom command
write_byte(0x44); // Temperature convert command
output_float(DQ);
delay_ms(750); // Max. conv. time is 750mS for 12 bit
ow_reset();
// Now get the device raw temperature data using Match ROM with the
// addresses obtained with FindDevices(). Scale to deg. C, scaling is
// 0.0625 (1/16) deg. C/bit with default 12 bit res. Could reduce res.
// and therefore shorten conversion time if necessary.
// Output the temperatures in whole degrees, apply rounding by adding
// half denom.
for (numROMs=1;numROMs<=4;numROMs++)
for (i=0;i<=7;i++)
ow_reset();
printf(lcd_putc,"\fSenzor Error!");
then:
while(1){
Wayne_
Posted: Fri Oct 09, 2009 3:33 am |
So which error are you still getting and what is the line ? please show code surrounding this and any definitions as well. |
pyu
Posted: Fri Oct 09, 2009 3:41 am |
Error: Code: | *** Error 66 "C:\Car_LCD\CarLCD.c" Line 638(6,13): Previous identifier must be a pointer |
Line: Code: | Temp[numROMs - 1] = result; |
main.c:
#include <16F887.H>
#include <math.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,NOBROWNOUT,NOWRT
#use delay(clock = 20000000)
//#device adc=10 *=16 - ???
#define DQ PIN_E0 // One Wire Bus pin assignment
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
#use I2C(MULTI_MASTER,sda=RTC_SDA, scl=RTC_SCL)
#include "Flex_LCD420.c"
#include "CarLCD.h"
#include "CarLCD.c"
lcd_init();
output_float(DQ); // Set as input. 4k7 pullup on bus.
FindDevices();
ow_reset();
DisplayInformations();
CarLCD.h:
// Global variables
int8 Rom_Bit[8]; // Rom_Bit bit
int8 lastDiscrep = 0;
short doneFlag = 0;
int8 FoundROM[7][8]; // Table of found ROM codes, 8 bytes for each
int8 numROMs;
int8 dowcrc; // crc is accumulated in this variable
// crc lookup table
int8 const dscrc_table[] = {
0,94,188,226,97,63,221,131,194,156,126,32,163,253,31,65,
157,195,33,127,252,162,64,30,95,1,227,189,62,96,130,220,
35,125,159,193,66,28,254,160,225,191,93,3,128,222,60,98,
190,224,2,92,223,129,99,61,124,34,192,158,29,67,161,255,
70,24,250,164,39,121,155,197,132,218,56,102,229,187,89,7,
219,133,103,57,186,228,6,88,25,71,165,251,120,38,196,154,
101,59,217,135,4,90,184,230,167,249,27,69,198,152,122,36,
248,166,68,26,153,199,37,123,58,100,134,216,91,5,231,185,
140,210,48,110,237,179,81,15,78,16,242,172,47,113,147,205,
17,79,173,243,112,46,204,146,211,141,111,49,178,236,14,80,
175,241,19,77,206,144,114,44,109,51,209,143,12,82,176,238,
50,108,142,208,83,13,239,177,240,174,76,18,145,207,45,115,
202,148,118,40,171,245,23,73,8,86,180,234,105,55,213,139,
87,9,235,181,54,104,138,212,149,203,41,119,244,170,72,22,
233,183,85,11,136,214,52,106,43,117,151,201,74,20,246,168,
116,42,200,150,21,75,169,247,182,232,10,84,215,137,107,53
// Returns 0 for one wire device presence, 1 for none
int8 ow_reset(void);
// Read bit on one wire bus
int8 read_bit(void);
void write_bit(int8 bitval) ;
int8 read_byte(void) ;
void write_byte(int8 val) ;
// One wire crc
int8 ow_crc(int8 x) ;
// Searches for the next device on the one wire bus. If there are no more
// devices on the bus then false is returned.
int8 Next(void);
// Resets current state of a ROM search and calls Next to find the first device
// on the one wire bus.
int8 First(void);
void FindDevices(void);
// Sends Match ROM command to bus then device address
int8 Send_MatchRom(void);
float Temp[4];
CarLCD.c:
//DS18B20
int8 ow_reset(void)
int8 presence;
output_low(DQ);
delay_us(488); // Min. 480uS
output_float(DQ);
delay_us(72); // Takes 15 to 60uS for devices to respond
presence = input(DQ);
delay_us(424); // Wait for end of timeslot
//printf(lcd_putc, "\fPresence= %i", presence);
//delay_ms(500);
return(presence);
int8 read_bit(void)
output_low(DQ);
delay_us(1); // 1uS min. Original code relied on 8051 being slow
output_float(DQ);
delay_us(20); // Wait at least 15mS from start of time slot
return(input(DQ)); // Delay to finish time slot (total 60 to 120uS)
} // must be done next.
output_low(DQ);
if(bitval == 1) {
output_float(DQ);
delay_us(105); // Wait for end of timeslot
output_float(DQ);
int8 i;
int8 val = 0;
for(i=0;i<8;i++)
if(read_bit()) val |= (0x01 << i);
delay_us(120); // To finish time slot
return val;
int8 i;
int8 temp;
for (i=0;i<8;i++)
temp = val >> i;
temp &= 0x01;
write_bit(temp);
delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
dowcrc = dscrc_table[dowcrc^x];
return dowcrc;
int8 Next(void)
int8 m = 1; // ROM Bit index
int8 n = 0; // ROM Byte index
int8 k = 1; // Bit mask
int8 x = 0;
int8 discrepMarker = 0;
int8 g; // Output bit
int8 nxt; // Return value
short flag;
nxt = FALSE; // Reset next flag to false
dowcrc = 0; // Reset the dowcrc
flag = ow_reset();
if (flag||doneFlag) // If no parts return false
lastDiscrep = 0; // Reset the search
return FALSE;
write_byte(0xF0); // Send SearchROM command
do
x = 0;
if (read_bit() == 1)
x = 2;
delay_us(120);
x |= 1; // And it's complement
if (x == 3) // There are no devices on the one wire bus
if (x > 0) // All devices coupled have 0 or 1
g = x >> 1; // Bit write value for search
// If this discrepancy is before the last discrepancy on a previous
// Next then pick the same as last time.
if (m < lastDiscrep)
g = ((Rom_Bit[n] & k) > 0);
// If equal to last pick 1
g = (m == lastDiscrep); // If not then pick 0
// If 0 was picked then record position with mask k
if (g == 0) discrepMarker = m;
// Isolate bit in Rom_Bit[n] with mask k
if (g == 1)
Rom_Bit[n] |= k;
Rom_Bit[n] &= ~k;
write_bit(g); // ROM search write
m++; // Increment bit counter m
k = k << 1; // and shift the bit mask k
// If the mask is 0 then go to new ROM
if (k == 0)
{ // Byte n and reset mask
ow_crc(Rom_Bit[n]); // Accumulate the crc
n++;
k++;
} while (n < 8); // Loop through until through all ROM bytes 0-7
if (m < (65||dowcrc)) // If search was unsuccessful then
lastDiscrep = 0; // reset the last Discrepancy to zero
else // Search was successful, so set lastDiscrep, lastOne, nxt
lastDiscrep = discrepMarker;
doneFlag = (lastDiscrep == 0);
nxt = TRUE; // Indicates search not yet complete, more parts remain
return nxt;
int8 First(void)
lastDiscrep = 0;
doneFlag = FALSE;
return Next(); // Call Next and return it's return value;
int8 m;
if(!ow_reset())
if(First()) // Begins when at least one part found
numROMs = 0;
do
numROMs++;
for (m=0;m<8;m++)
FoundROM[numROMs][m] = Rom_Bit[m]; // Identifies ROM no. on device
//printf("Device No.%u address ",numROMs);
//printf(lcd_putc,"%u no dev=",numROMs);
//delay_ms(1000);
printf(lcd_putc, "\f%X%X%X%X%X%X%X%X",
FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5], \
FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2], \
FoundROM[numROMs][1],FoundROM[numROMs][0]);
//printf("%X%X%X%X%X%X%X%X\n\r",
//FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5],
//FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2],
//FoundROM[numROMs][1],FoundROM[numROMs][0]);
} while (Next() && (numROMs<10)); // Continues until no additional
// devices found.
printf(lcd_putc, "\fno ROM found");
//delay_ms(500);
printf(lcd_putc, "\fno ROM found2");
//delay_ms(500);
//putc('\n'); putc('\r');
int8 i;
if (ow_reset()) return FALSE; // 0 if device present
write_byte(0x55); // Match ROM
for (i=0;i<8;i++)
write_byte(FoundRom[numROMs][i]); // Send ROM code
return TRUE;
void DisplayInformations(void)
Read_DS_Temperature();
int8 i;
int8 scratch[9];
signed int16 temp;
float result=0;
output_float(DQ);
ow_reset();
// half denom.
for (i=0;i<=7;i++)
ow_reset();
Posted: Fri Oct 09, 2009 4:11 am |
It's a simple matter of code confusion.
On one hand you're utilizing the default case insensitive behaviour of CCS C (you get many errors, when activating #case for you code), on the other hand you have this:
Code: | int16 temp;
// and at another place
float Temp[4]; |
Decide, if you are going for #case or #nocase and correct your code respectively. |
pyu
Posted: Mon Oct 12, 2009 3:55 am |
Thanks FvM.
It's working now! |
