Linuxbuilders
modbus slave |
Posted: Wed Mar 07, 2012 3:14 am |
Hi, I use standard slave implemetation from CCS example ex_modbus_slave.c
Just raw copy with PIC specific adjustments. As scada software I use Free Scada with RTU support over serial port.
This is what scada sends to pic: 0201000700014C38
This is what it gets back from my pic: 02020100A1CC
This is what scada sends to pic: 0201000000083DFF
This is what it gets back from my pic: 0202010561CF
This is what scada sends to pic: A70100000001E50C
This is what it gets back from my pic: A702010142C0
Response from PIC looks invalid - as far I understand it should be 020100A1CC not 02020100A1CC or A702010142C0 if I change an address to 0xA7 form 0x02
Any suggestions? Anyone knows about any compatibility issues?
Thank you.
front part of the program
#include <18F4520.h> //libs from compiler
#device ADC=10 //analogue to digital converter init specs
//#DEVICE HIGH_INTS=TRUE
#include <ctype.h> //libs from compiler
#include <stddef.h> //libs from compiler
#include <string.h> //libs from compiler
//=========DEFINE====================
#define MODBUS_SERIAL_RX_PIN PIN_C7 // serial data receive pin
#define MODBUS_SERIAL_TX_PIN PIN_C6 // serial data transmit pin
#define MODBUS_SERIAL_ENABLE_PIN PIN_B1 // serial TX on
#define STATUSL PIN_B0 // status led
#define GOUT1 PIN_D7
#define GOUT2 PIN_D6
#define GOUT3 PIN_D5
#define GOUT4 PIN_D4
#define GOUT5 PIN_C5
#define GOUT6 PIN_C4
#define BUZZ PIN_D2
#define POWER PIN_D0
#define BATTERY PIN_D1
#define MAINS_TEST PIN_AN5
#define POWER_TEST PIN_AN6
#define BATTERY_TEST PIN_AN7
#define INTMP PIN_AN0
#define TMP1 PIN_AN1
#define A1 PIN_AN2
#define A2 PIN_AN3
#define A3 PIN_AN4
#define BATTERY_TEST_ON PIN_B5
#define IN1 PIN_B2
#define IN2 PIN_A4
#define IN3 PIN_C3
#define IN4 PIN_C2
#define IN5 PIN_C1
#define IN6 PIN_C0
#define IN7 PIN_B4
#define IN8 PIN_B3
#define MODBUS_SERIAL_TYPE MODBUS_RTU //use MODBUS_ASCII for ASCII mode
#define MODBUS_SERIAL_RX_BUFFER_SIZE 64
#define MODBUS_SERIAL_BAUD 9600
//#define MODBUS_SERIAL_RX_ENABLE 0 // Controls RE pin for RS485
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_RDA
#FUSES H4
#FUSES MCLR
#FUSES BROWNOUT
#FUSES NODEBUG
#FUSES NOPROTECT
#FUSES NOWDT
#FUSES PUT
#FUSES NOCPD
#FUSES NOXINST // Config: ext reset, no code protect, no watchdog, high speed clock
#use delay (clock=40M, oscillator=10M)
#use fixed_io(D_outputs=GOUT1,GOUT2,GOUT3,GOUT4,BUZZ,POWER,BATTERY)
#use fixed_io(A_outputs=)
#use fixed_io(B_outputs=STATUSL,MODBUS_SERIAL_ENABLE_PIN,BATTERY_TEST_ON)
#use fixed_io(C_outputs=MODBUS_SERIAL_TX_PIN,GOUT5,GOUT6)
#use fixed_io(E_outputs=)
#include <modbus.c>
#define MODBUS_ADDRESS 0x02
int timer = 0;
int timerstep = 0;
int timerstep2 = 0;
int timerstep3 = 0;
#int_RTCC
void timer0_isr(void) {
timer++;
if (timer == 0) {
output_high(STATUSL);
if (timer == 0xFF) {
timerstep++;
if (timerstep == 128) {
output_low(STATUSL);
if (timerstep == 0xFF) {
timerstep2++;
if (timerstep2 == 0xFF) {
timerstep3++;
if (timerstep3 == 0x05) {
int8 swap_bits(int8 c)
return ((c&1)?128:0)|((c&2)?64:0)|((c&4)?32:0)|((c&8)?16:0)|((c&16)?8:0)
|((c&32)?4:0)|((c&64)?2:0)|((c&128)?1:0);
//=========MAIN PROGRAM==============
void main() { // main program
int i;
int8 coils = 0b00000101;
int8 inputs = 0b00001001;
int16 hold_regs[] = {0x8800,0x7700,0x6600,0x5500,0x4400,0x3300,0x2200,0x1100};
int16 input_regs[] = {0x1100,0x2200,0x3300,0x4400,0x5500,0x6600,0x7700,0x8800};
int16 event_count = 0;
setup_wdt(WDT_OFF); //set watch dog timer
disable_interrupts(GLOBAL); //clear interrupts
set_timer0(0); //clear timers
set_rtcc(0); //clear timers
setup_timer_0(RTCC_INTERNAL | RTCC_8_BIT | T0_DIV_1); //set timer 0 parameters
setup_adc_ports(AN0_TO_AN7 | VSS_VDD); //set AD ports
setup_adc(ADC_CLOCK_DIV_16 | ADC_TAD_MUL_16); //ADC_CLOCK_INTERNAL |
setup_comparator(NC_NC_NC_NC); //turn off comparators
enable_interrupts(GLOBAL); //clear interrupts
//enable_interrupts(int_rda); //enable serial port
enable_interrupts(INT_RTCC); //enable TIMERs
//=========BOOT UP===================
//output_low(TX_ON);
output_low(GOUT1);
output_low(GOUT2);
output_low(GOUT3);
output_low(GOUT4);
output_low(GOUT5);
output_low(GOUT6);
output_low(BUZZ);
output_low(POWER);
output_low(BATTERY);
output_high(BUZZ);
delay_ms(150);
output_low(BUZZ);
delay_ms(150);
output_high(BUZZ);
delay_ms(150);
output_low(BUZZ);
delay_ms(150);
output_high(BUZZ);
delay_ms(150);
output_low(BUZZ);
modbus_init();
then rest follows as per while loop from example file
CCS V4.114 in use _________________ Help "d" others and then you shell receive some help from "d" others. |
FvM
Posted: Wed Mar 07, 2012 1:04 pm |
It's a trivial copy and past error in ex_modbus_slave.c
Change the below code
Code: | if(modbus_rx.func == FUNC_READ_COILS)
modbus_read_discrete_input_rsp(MODBUS_ADDRESS, 0x01, &data);
modbus_read_discrete_input_rsp(MODBUS_ADDRESS, 0x01, &data); |
to
modbus_read_coils_rsp(MODBUS_ADDRESS, 0x01, &data);
Linuxbuilders
Posted: Wed Mar 07, 2012 11:41 pm |
working, thank you. _________________ Help "d" others and then you shell receive some help from "d" others. |
bbnnbb
HELP |
Posted: Sun Mar 11, 2012 4:15 am |
HELLO SIR I HAVE THE SAME PROJECT AS YOU SO I NEED HELP ESPECIALY WICH SCADA SOFTWARE YOU USED AND IF POSSIBLE SEND ME THE INTERFACE.
No more ALL CAPS in post.
No ALL CAPS in sigline.
- Forum Moderator
++++++++++++++++++++ _________________ HELLO EVERY BODY!,AM WORKING IN MY FINAL PROJECT IN IMPLEMENTATION OF THE MODBUS AND INTERFACING WITH HMI SO I NEED HELP IN MY PROJECT (I USE LIBRARY MODBUS OF CCS) |
Linuxbuilders
Posted: Sun Mar 11, 2012 12:49 pm |
You can expect help but not entire solution. _________________ Help "d" others and then you shell receive some help from "d" others. |
