modbus slave
Linuxbuilders
modbus slave
PostPosted: Wed Mar 07, 2012 3:14 am     Reply with quote
Hi, I use standard slave implemetation from CCS example ex_modbus_slave.c
Just raw copy with PIC specific adjustments. As scada software I use Free Scada with RTU support over serial port.
This is what scada sends to pic: 0201000700014C38
This is what it gets back from my pic: 02020100A1CC
This is what scada sends to pic: 0201000000083DFF
This is what it gets back from my pic: 0202010561CF
This is what scada sends to pic: A70100000001E50C
This is what it gets back from my pic: A702010142C0
Response from PIC looks invalid - as far I understand it should be 020100A1CC not 02020100A1CC or A702010142C0 if I change an address to 0xA7 form 0x02
Any suggestions? Anyone knows about any compatibility issues?
Thank you.
front part of the program
#include <18F4520.h> //libs from compiler
#device ADC=10 //analogue to digital converter init specs
//#DEVICE HIGH_INTS=TRUE
#include <ctype.h> //libs from compiler
#include <stddef.h> //libs from compiler
#include <string.h> //libs from compiler
//=========DEFINE====================
#define MODBUS_SERIAL_RX_PIN                 PIN_C7            //    serial data receive pin
#define MODBUS_SERIAL_TX_PIN                 PIN_C6            //    serial data transmit pin
#define MODBUS_SERIAL_ENABLE_PIN             PIN_B1            //    serial TX on
#define STATUSL            PIN_B0            //    status led
#define GOUT1              PIN_D7
#define GOUT2              PIN_D6
#define GOUT3              PIN_D5
#define GOUT4              PIN_D4
#define GOUT5              PIN_C5
#define GOUT6              PIN_C4
#define BUZZ               PIN_D2
#define POWER              PIN_D0
#define BATTERY            PIN_D1
#define MAINS_TEST         PIN_AN5
#define POWER_TEST         PIN_AN6
#define BATTERY_TEST       PIN_AN7
#define INTMP              PIN_AN0
#define TMP1               PIN_AN1
#define A1                 PIN_AN2
#define A2                 PIN_AN3
#define A3                 PIN_AN4
#define BATTERY_TEST_ON    PIN_B5
#define IN1              PIN_B2
#define IN2              PIN_A4
#define IN3              PIN_C3
#define IN4              PIN_C2
#define IN5              PIN_C1
#define IN6              PIN_C0
#define IN7              PIN_B4
#define IN8              PIN_B3
#define MODBUS_TYPE MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_TYPE MODBUS_RTU     //use MODBUS_ASCII for ASCII mode
#define MODBUS_SERIAL_RX_BUFFER_SIZE 64
#define MODBUS_SERIAL_BAUD 9600
//#define MODBUS_SERIAL_RX_ENABLE    0   // Controls RE pin for RS485
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_RDA
#FUSES H4
#FUSES MCLR
#FUSES BROWNOUT
#FUSES NODEBUG
#FUSES NOPROTECT
#FUSES NOWDT
#FUSES PUT
#FUSES NOCPD
#FUSES NOXINST  // Config: ext reset, no code protect, no watchdog, high speed clock
#use delay (clock=40M, oscillator=10M)
#use fixed_io(D_outputs=GOUT1,GOUT2,GOUT3,GOUT4,BUZZ,POWER,BATTERY)
#use fixed_io(A_outputs=)
#use fixed_io(B_outputs=STATUSL,MODBUS_SERIAL_ENABLE_PIN,BATTERY_TEST_ON)
#use fixed_io(C_outputs=MODBUS_SERIAL_TX_PIN,GOUT5,GOUT6)
#use fixed_io(E_outputs=)
#include <modbus.c>
#define MODBUS_ADDRESS 0x02
int timer = 0;
int timerstep = 0;
int timerstep2 = 0;
int timerstep3 = 0;
#int_RTCC
void timer0_isr(void) {
   timer++;
   if (timer == 0) {
      output_high(STATUSL);
   if (timer == 0xFF) {
      timerstep++;
   if (timerstep == 128) {
      output_low(STATUSL);
   if (timerstep == 0xFF) {
      timerstep2++;
   if (timerstep2 == 0xFF) {
      timerstep3++;
   if (timerstep3 == 0x05) {
int8 swap_bits(int8 c)
   return ((c&1)?128:0)|((c&2)?64:0)|((c&4)?32:0)|((c&8)?16:0)|((c&16)?8:0)
          |((c&32)?4:0)|((c&64)?2:0)|((c&128)?1:0);
//=========MAIN PROGRAM==============
void main() {  // main program
int i;
int8 coils = 0b00000101;
int8 inputs = 0b00001001;
int16 hold_regs[] = {0x8800,0x7700,0x6600,0x5500,0x4400,0x3300,0x2200,0x1100};
int16 input_regs[] = {0x1100,0x2200,0x3300,0x4400,0x5500,0x6600,0x7700,0x8800};
int16 event_count = 0;
setup_wdt(WDT_OFF);            //set watch dog timer
disable_interrupts(GLOBAL);    //clear interrupts
set_timer0(0);               //clear timers
set_rtcc(0);               //clear timers
setup_timer_0(RTCC_INTERNAL | RTCC_8_BIT | T0_DIV_1); //set timer 0 parameters
setup_adc_ports(AN0_TO_AN7 | VSS_VDD); //set AD ports
setup_adc(ADC_CLOCK_DIV_16 | ADC_TAD_MUL_16);  //ADC_CLOCK_INTERNAL |
setup_comparator(NC_NC_NC_NC);   //turn off comparators
enable_interrupts(GLOBAL);       //clear interrupts
//enable_interrupts(int_rda);      //enable serial port
enable_interrupts(INT_RTCC);     //enable TIMERs
//=========BOOT UP===================
   //output_low(TX_ON);
   output_low(GOUT1);
   output_low(GOUT2);
   output_low(GOUT3);
   output_low(GOUT4);
   output_low(GOUT5);
   output_low(GOUT6);
   output_low(BUZZ);
   output_low(POWER);
   output_low(BATTERY);
   output_high(BUZZ);
   delay_ms(150);
   output_low(BUZZ);
   delay_ms(150);
   output_high(BUZZ);
   delay_ms(150);
   output_low(BUZZ);
   delay_ms(150);
   output_high(BUZZ);
   delay_ms(150);
   output_low(BUZZ);
   modbus_init();
then rest follows as per while loop from example file
CCS V4.114 in use
Help "d" others and then you shell receive some help from "d" others.
PostPosted: Wed Mar 07, 2012 1:04 pm     Reply with quote
It's a trivial copy and past error in ex_modbus_slave.c
Change the below code
if(modbus_rx.func == FUNC_READ_COILS)
  modbus_read_discrete_input_rsp(MODBUS_ADDRESS, 0x01, &data);
to
  modbus_read_coils_rsp(MODBUS_ADDRESS, 0x01, &data);
Linuxbuilders
PostPosted: Wed Mar 07, 2012 11:41 pm     Reply with quote
working, thank you.
bbnnbb
HELP
PostPosted: Sun Mar 11, 2012 4:15 am     Reply with quote
HELLO SIR I HAVE THE SAME PROJECT AS YOU SO I NEED HELP ESPECIALY WICH SCADA SOFTWARE YOU USED AND IF POSSIBLE SEND ME THE INTERFACE.
No more ALL CAPS in post.
No ALL CAPS in sigline.
- Forum Moderator
HELLO EVERY BODY!,AM WORKING IN MY FINAL PROJECT IN IMPLEMENTATION OF THE MODBUS AND INTERFACING WITH HMI SO I NEED HELP IN MY PROJECT (I USE LIBRARY MODBUS OF CCS)
Linuxbuilders
PostPosted: Sun Mar 11, 2012 12:49 pm     Reply with quote
You can expect help but not entire solution.
