18F86K22 and RS232
curt2go
18F86K22 and RS232
PostPosted: Mon May 30, 2011 5:49 pm     Reply with quote
I have used RS232 on many different devices. All without an issue. I usually use a MAX232A to do the interfacing but sometimes a FET. But this time I am using a MAX232A. Exact same circuit as always BUT for some reason I am not getting things to go right to the computer. I am getting something but it is not the right chars when it gets to the computer. I am using a verified cable and I can see that the data is coming out of the TX line from the PIC. Just wondering if anyone has has issues with this chip. I am using 9600 baud 8,n,1. Very simple. I have even cut everything else out of my code and am making a simple loop to just send something out the RS232 every 2 seconds. It is driving me crazy!!! Any help would be great. Thanx
PostPosted: Mon May 30, 2011 6:16 pm     Reply with quote
You need to post your version on this type of question.
Assuming it's an earlier version, here is one possible bug and the solution:
http://www.ccsinfo.com/forum/viewtopic.php?t=43961
curt2go
PostPosted: Mon May 30, 2011 6:28 pm     Reply with quote
Sorry. Stupid me.. 4.116.
curt2go
PostPosted: Mon May 30, 2011 6:41 pm     Reply with quote
Downloaded 4.121. It is now fixed. I guess I should have looked here about 8 hours ago.. Smile Never thought it would be the compiler.. Thanx for the help.. TTY
