I have used RS232 on many different devices. All without an issue. I usually use a MAX232A to do the interfacing but sometimes a FET. But this time I am using a MAX232A. Exact same circuit as always BUT for some reason I am not getting things to go right to the computer. I am getting something but it is not the right chars when it gets to the computer. I am using a verified cable and I can see that the data is coming out of the TX line from the PIC. Just wondering if anyone has has issues with this chip. I am using 9600 baud 8,n,1. Very simple. I have even cut everything else out of my code and am making a simple loop to just send something out the RS232 every 2 seconds. It is driving me crazy!!! Any help would be great. Thanx
Downloaded 4.121. It is now fixed. I guess I should have looked here about 8 hours ago.. Never thought it would be the compiler.. Thanx for the help.. TTY
