privacy
| Rtos Help |
Posted: Mon Jan 24, 2011 5:11 pm |
Hello friends, I am an electrical&electronics engineering student and I need help with my code. I want to use disable_rtos and enable_rtos codes but I can't make it. Here is a sample code for this. How can I do this?
#include <18F452.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#use rtos(timer=0, minor_cycle=10ms)
// Declare TASK 1 - called every 250ms
#task(rate=250ms, max=10ms)
void task_B0()
output_toggle(PIN_B0); // Toggle RB0
// Declare TASK 2 - called every 500ms
#task(rate=500ms, max=10ms)
void task_B1()
output_toggle(PIN_B1); // Toggle RB1
// Declare TASK 3 - called every second
#task(rate=1s, max=10ms)
void task_B2()
output_toggle(PIN_B2); // Toggle RB2
// Declare TASK 4 - called every 2 seconds
#task(rate=2s, max=10ms)
void task_B3()
output_toggle(PIN_B3); // Toggle RB3
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
// TODO: USER CODE!!
rtos_run();
rtos_disable(task_B1);
rtos_disable(task_B2);
rtos_disable(task_B3);
dyeatman
Posted: Mon Jan 24, 2011 5:27 pm |
What version of compiler do you have? _________________ Google and Forum Search are some of your best tools |
privacy
Posted: Mon Jan 24, 2011 5:30 pm |
| version 4.068 |
