Rtos Help
privacy
Rtos Help
PostPosted: Mon Jan 24, 2011 5:11 pm     Reply with quote
Hello friends, I am an electrical&electronics engineering student and I need help with my code. I want to use disable_rtos and enable_rtos codes but I can't make it. Here is a sample code for this. How can I do this?
#include <18F452.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#use rtos(timer=0, minor_cycle=10ms)
// Declare TASK 1 - called every 250ms
#task(rate=250ms, max=10ms)
void task_B0()
output_toggle(PIN_B0); // Toggle RB0
// Declare TASK 2 - called every 500ms
#task(rate=500ms, max=10ms)
void task_B1()
output_toggle(PIN_B1); // Toggle RB1
// Declare TASK 3 - called every second
#task(rate=1s, max=10ms)
void task_B2()
output_toggle(PIN_B2); // Toggle RB2
// Declare TASK 4 - called every 2 seconds
#task(rate=2s, max=10ms)
void task_B3()
output_toggle(PIN_B3); // Toggle RB3
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
   // TODO: USER CODE!!
rtos_run();
rtos_disable(task_B1);
rtos_disable(task_B2);
rtos_disable(task_B3);
PostPosted: Mon Jan 24, 2011 5:27 pm     Reply with quote
What version of compiler do you have?
privacy
PostPosted: Mon Jan 24, 2011 5:30 pm     Reply with quote
version 4.068
