SPI FLASH (NexFlash NX25P40 or ST 25P40)
cfernandez
PostPosted: Mon Aug 01, 2005 11:18 am     Reply with quote
I need to know if somebody use this flash memory and which is your opinion?, and if know where found the code library for this.
I have another question, Is possible write only one Byte without read the page or I have to read the page (256 bytes), then modify the byte and then write the page complete.?????
Thank you very much!!
mp3fusion
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Mon Aug 01, 2005 3:08 pm     Reply with quote
I have used the flash memory ... It is really good ... and easy to implement
If you need the driver for it ... just e-mail me at jilanski@yahoo.com
Shortly I am going to put it in the library ...
Farzad
mp3fusion
consideration about voltage
PostPosted: Mon Aug 01, 2005 3:14 pm     Reply with quote
I also remembered something ... the flash runs at 2.7 to 3.6 volts ...
you have to use a level shifter to change the spi flash output from 5 to 3.6
