I need to know if somebody use this flash memory and which is your opinion?, and if know where found the code library for this.
I have another question, Is possible write only one Byte without read the page or I have to read the page (256 bytes), then modify the byte and then write the page complete.?????
Thank you very much!!
mp3fusion
Posted: Mon Aug 01, 2005 3:08 pm
I have used the flash memory ... It is really good ... and easy to implement
