and loaded the tinybld18F2620.HEX to controller then i tried to detect the hardware using tinybldWin.exe
which was successful and the message showed was
Connected to \\.\COM1 at 115200
Searching for PIC ...
Found:18F 2620/4620
Then i tried to load my application but following error came
HEX: 8 min old, INHX32,18Fcode+cfg, total=33844 bytes.
Found:18F 2620/4620
Could not write
ERROR!
I am also using hardware UART pin c6 and pin c7 for other purpose with baud rate of 9600.
Kindly suggest me a solution as i am stuck,
Thanks _________________ sohail khan
sohailkhanonline
Posted: Fri May 16, 2008 6:57 am
problem solved, I was using same UART for other application
