bootloader help
sohailkhanonline
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
bootloader help
PostPosted: Fri May 16, 2008 1:23 am     Reply with quote
hi
I am using tiny bootloader for my application i have followed all the steps of the post
http://www.ccsinfo.com/forum/viewtopic.php?t=34065&highlight=tiny+bootloader
The device i am using is 18F4620 with clock of 20MHz
and the hex file in the directory \picsource\18f
tinybld18F2620.HEX
as my device was not listed then i changed the following
in the file icdpictypes.inc
previously
IFDEF __18F2620
      #include "p18f2620.inc"
IdTypePIC = 0x4F
      #define max_flash 0x10000
   ENDIF
   IFDEF __18F4620
      #include "p18f4620.inc"
IdTypePIC = 0x4F
   ENDIF
changed
IFDEF __18F2620
IdTypePIC = 0x4F
   ENDIF
   IFDEF __18F4620
IdTypePIC = 0x4F
   ENDIF
and loaded the tinybld18F2620.HEX to controller then i tried to detect the hardware using tinybldWin.exe
which was successful and the message showed was
Connected to \\.\COM1 at 115200
  Searching for PIC ...
  Found:18F 2620/4620
Then i tried to load my application but following error came
  HEX: 8 min old, INHX32,18Fcode+cfg, total=33844 bytes.
  Found:18F 2620/4620
  Could not write
  ERROR!
I am also using hardware UART pin c6 and pin c7 for other purpose with baud rate of 9600.
Kindly suggest me a solution as i am stuck,
sohail khan
sohailkhanonline
PostPosted: Fri May 16, 2008 6:57 am     Reply with quote
problem solved, I was using same UART for other application
Very Happy
sohail khan
