What is the purpose of no load resistors? For example on the Explorer 16 R54 is a no load. From what I see R54 is connected on one side to the 3.3v RF7 and the other side to the 5v RF7_E where the voltage conversion from 3.3 to 5v is done. So is R54 used for test points? Or do they put R54 so you could bridge across and have 3.3v on the external connector?
TIA
Posted: Fri Apr 25, 2008 10:38 am
This is a Microchip development board. You should ask your question
in the "Evaluation and Demonstration Boards" forum on the Microchip
website. Here's the link:
http://forum.microchip.com/tt.aspx?forumid=181
