Can you write to Program Memory while the PIC is running?
Posted: Wed Apr 09, 2008 4:15 pm
PIC16F690-ICD / ICD2 / PCM 4.060
Using the write_program_memory function or any other function? I need to take in a 520 byte command string. Thanks!
Posted: Wed Apr 09, 2008 4:28 pm
Look in the 16F690 data sheet, in section 10.0.
http://ww1.microchip.com/downloads/en/DeviceDoc/41262E.pdf
Look in the table of contents on the left side in the Acrobat reader.
If a PIC can write to Flash Program Memory, the data sheet will
very prominently have sections on Writing and Erasing that memory.
Thanks so much. I just read the data sheet right before I read your comment. I also tried the write_program_memory and it didn't work and the read_program_memory did. Thanks for the confirmation.
