Can you write to Program Memory while the PIC is running?
ThomasC
PostPosted: Wed Apr 09, 2008 4:15 pm     Reply with quote
PIC16F690-ICD / ICD2 / PCM 4.060
Using the write_program_memory function or any other function? I need to take in a 520 byte command string. Thanks!
PostPosted: Wed Apr 09, 2008 4:28 pm     Reply with quote
Look in the 16F690 data sheet, in section 10.0.
http://ww1.microchip.com/downloads/en/DeviceDoc/41262E.pdf
Look in the table of contents on the left side in the Acrobat reader.
If a PIC can write to Flash Program Memory, the data sheet will
very prominently have sections on Writing and Erasing that memory.
Compare that data sheet to the 16F88. Look in section 3.0
and see what it shows in the table of contents:
http://ww1.microchip.com/downloads/en/DeviceDoc/30487c.pdf
ThomasC
PostPosted: Wed Apr 09, 2008 4:48 pm     Reply with quote
Thanks so much. I just read the data sheet right before I read your comment. I also tried the write_program_memory and it didn't work and the read_program_memory did. Thanks for the confirmation.
*solved*
