nmeyer
flex_lcd and setting cursor |
Posted: Tue Mar 25, 2008 1:28 pm |
I am putting together code to have a blinking cursor on my screen. from reading other posts on this forum I have found that i can control the position of the cursor by using the lcd_gotoxy() function. Also, it looks like if i change the array in flex_lcd to
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xf, // Display on was 0xc
1, // Clear display
6 // Increment cursor
the cursor will blink. However, now the cursor is always on at the end of the second line of my lcd display. Is there something else i should do to turn the blinking cursor on only when i want it?
Thanks |
Posted: Tue Mar 25, 2008 1:45 pm |
Quote: |
Is there something else i should do to turn the blinking cursor on only when i want it? |
See this post in the Code library for a routine to control the lcd cursor:
http://www.ccsinfo.com/forum/viewtopic.php?t=24668 |
nmeyer
Posted: Tue Mar 25, 2008 2:49 pm |
Thanks. I saw this in my previous searching but i was not sure that is was what i wanted or exactly how to use it. I played with it a bit and i have it working. |
