Pointer Examples? (Solved)
ThomasC
PostPosted: Fri Mar 21, 2008 2:11 pm     Reply with quote
PIC16F690-ICD / ICD2 / PCM 4.060
I'm having trouble declaring and implementing pointers to send a float as a string of bytes through an array. I'm assuming a float would be 4 bytes, since float is 32 bits. Can someone show me some links and/or examples? I've searched the forum and through google. Thanks so much.
PostPosted: Fri Mar 21, 2008 3:10 pm     Reply with quote
See this FAQ article:
http://www.ccsinfo.com/faq.php?page=write_eeprom_not_byte
ThomasC
PostPosted: Fri Mar 21, 2008 3:41 pm     Reply with quote
Thanks I found out my code did not work because I tried to declare the pointer inside a function instead of outside the function.
*Solved*
