JULIEN LAFFITTE
| one wire search rom problem |
Posted: Thu Jan 17, 2008 11:34 am |
Hello
I m trying to implement the SEARCH ROM command on my application.
But when I compile a problem appear on this line, in the include for one wire device:
int8 ROM[8]; // ROM bit
I don't think the error was in the main file or in the include for ds18b20/ds1822 but was in the variable declaration of the one wire device include file.
Main file:
#include <18F2523.H>
#fuses HS,NOPROTECT,NOBROWNOUT,NOWDT,WDT4096,PUT,NOCPD,NOSTVREN,NODEBUG,NOLVP,NOWRT,NOFCMEN//4s: WDT1024
#define DQ PIN_B1
#include <string.h>
#include <stdlib.h>
#include <owire_v2.c>
#include <ds18b20.c>
float temperature_c;
printf("connecting to DS1820 -----\r\n");
while (TRUE){
delay_ms(2000);
if (!ow_reset()) {
// set the number of bits of resolution on the ds1822.
// note that this affects the conversion time,
// RTFM and see the called function.
onewire_ds1822_set_temperature_resolution(12);
// read the temperature from the ds1822.
// note that the returned value is in deg C,
// and the "lite" function returns only positive temps.
temperature_c = onewire_ds1822_read_temp_c_lite();
printf( "Temperature C= %10.2f degrees C \r\n", temperature_c ); // print temperature C
delay_ms (1000);
printf("onewire device not found\r\n");
}//end while(1)
}// end of main()
include for ds18b20 or ds1822:
// 16F877A Pin 33 (RB0) connected to DS1820 Pin2 (DQ).
// 16F877A Pin 33 (RB0) also connect to 4.7K resistor pulled up to +5V.
// 16F877A Pin 25 (RC6/Tx) connected to MAX232 which is then connected to PC serial Port.
// ds1822 scratchpad registers
#define DS1822_SP_TLSB 0
#define DS1822_SP_TMSB 1
#define DS1822_SP_HLIM 2
#define DS1822_SP_LLIM 3
#define DS1822_SP_CFG 4
#define DS1822_SP_RES0 5
#define DS1822_SP_RES1 6
#define DS1822_SP_RES2 7
#define DS1822_SP_CRC 8
// ds1822 rom registers
#define DS1822_ROM_DEVTYPE 0
#define DS1822_ROM_SERIAL1 1
#define DS1822_ROM_SERIAL2 2
#define DS1822_ROM_SERIAL3 3
#define DS1822_ROM_SERIAL4 4
#define DS1822_ROM_SERIAL5 5
#define DS1822_ROM_SERIAL6 6
#define DS1822_ROM_CRC 7
// ds1822 command set
#define DS1822_CMD_READROM 0x33
#define DS1822_CMD_SKIPROM 0xCC
#define DS1822_CMD_CONVERTTEMP 0x44
#define DS1822_CMD_WRITESCRATCHPAD 0x4E
#define DS1822_CMD_READSCRATCHPAD 0xBE
#define DS1822_CMD_COPYSCRATCHPAD 0x48
// note that not all applications need to disable interrupts when
// performing onewire transactions. but, if unmasked interrupts
// cause onewire timing violations, returned data will be suspect
// or there may be other, hard-to-reproduce problems.
int onewire_ds1822_read_scratchpad(int field) { /* returns config bitfield */
int data[9];
ow_reset();
write_byte(DS1822_CMD_SKIPROM);
write_byte(DS1822_CMD_READSCRATCHPAD);
data[DS1822_SP_TLSB]=read_byte(); // 0 Tlsb
data[DS1822_SP_TMSB]=read_byte(); // 1 Tmsb
data[DS1822_SP_HLIM]=read_byte(); // 2 Thlim
data[DS1822_SP_LLIM]=read_byte(); // 3 Tllim
data[DS1822_SP_CFG]=read_byte(); // 4 Config
data[DS1822_SP_RES0]=read_byte(); // 5 RES0
data[DS1822_SP_RES1]=read_byte(); // 6 RES1
data[DS1822_SP_RES2]=read_byte(); // 7 RES2
data[DS1822_SP_CRC]=read_byte(); // 8 CRC
if (field > 8) {
//printf(debug_putc,"ERR! >scratchpad field 0x%x out of range (ds1822)\n\r",field);
return(0);
else {
//printf(debug_putc,"0x%x >scratchpad field 0x%x (ds1822)\n\r",data[field],field);
return(data[field]);
int onewire_ds1822_read_rom(int field) { /* rtns ROM info, one byte at a time */
int data[8];
if (!ow_reset())
return (0);
write_byte(DS1822_CMD_READROM);
data[DS1822_ROM_DEVTYPE]=read_byte(); // 0 family code
data[DS1822_ROM_SERIAL1]=read_byte(); // 1 serial number LSB
data[DS1822_ROM_SERIAL2]=read_byte(); // 2 serial number
data[DS1822_ROM_SERIAL3]=read_byte(); // 3 serial number
data[DS1822_ROM_SERIAL4]=read_byte(); // 4 serial number
data[DS1822_ROM_SERIAL5]=read_byte(); // 5 serial number
data[DS1822_ROM_SERIAL6]=read_byte(); // 6 serial number MSB
data[DS1822_ROM_CRC]=read_byte(); // 7 CRC
if (field > 7) {
//printf(debug_putc,"ERR! >rom field 0x%x out of range (ds1822)\n\r",field);
return(0);
else {
//printf(debug_putc,"0x%x >rom field 0x%x (ds1822)\n\r",data[field],field);
int onewire_ds1822_set_temperature_resolution(int resolution) { /* set up for nbit resolution */
int resolution_cfgfield;
if ((resolution < 9) || (resolution > 12))
resolution=9;
resolution_cfgfield=((resolution-9)<<5); // see DS1822 datasheet page 7
if (ow_reset())
return (0);
write_byte(DS1822_CMD_WRITESCRATCHPAD);
write_byte(0b01111101); // set max TH threshold (125'C)
write_byte(0b11001001); // set min TL threshold (-55'C)
write_byte(resolution_cfgfield); // Temp resolution, set to nbit
ow_reset(); // reset
write_byte(DS1822_CMD_COPYSCRATCHPAD);
delay_ms(15); // allow time for flash memory write.
return( (onewire_ds1822_read_scratchpad(DS1822_SP_CFG) & 0b01100000)>>5 );
float onewire_ds1822_read_temp_c_lite() {
int temperatureLSB, temperatureMSB, config, delaymult;
signed int16 temp16;
float temperature;
config=((onewire_ds1822_read_scratchpad(DS1822_SP_CFG) && 0b01100000)>>5);
// each addn'l resolution bit needs twice the base conversion time!
if (ow_reset())
return (0);
write_byte(DS1822_CMD_CONVERTTEMP);
delaymult=1<<config;
//printf(debug_putc,"0x%x >delay_mult (ds1822)\n\r",delaymult);
while (delaymult--)
delay_ms(100); // allow worst case time for temp. conversion.
temperatureLSB = onewire_ds1822_read_scratchpad(DS1822_SP_TLSB);
temperatureMSB = onewire_ds1822_read_scratchpad(DS1822_SP_TMSB);
temp16= make16(temperatureMSB, temperatureLSB);
temperature = (float) temp16 / 16.0;
return(temperature);
// One Wire bus functions - from Dallas publication AN162
// "Interfacing DS18x20/DS1822 1-wire Temperature Sensor in a uC Environment"
// Delays calculated from values given for 8051 in source code
// Global variables
int8 lastDiscrep = 0;
short doneFlag = 0;
int8 FoundROM[7][8]; // Table of found ROM codes, 8 bytes for each
int8 numROMs;
int8 dowcrc; // crc is accumulated in this variable
// crc lookup table
int8 const dscrc_table[] = {
0,94,188,226,97,63,221,131,194,156,126,32,163,253,31,65,
157,195,33,127,252,162,64,30,95,1,227,189,62,96,130,220,
35,125,159,193,66,28,254,160,225,191,93,3,128,222,60,98,
190,224,2,92,223,129,99,61,124,34,192,158,29,67,161,255,
70,24,250,164,39,121,155,197,132,218,56,102,229,187,89,7,
219,133,103,57,186,228,6,88,25,71,165,251,120,38,196,154,
101,59,217,135,4,90,184,230,167,249,27,69,198,152,122,36,
248,166,68,26,153,199,37,123,58,100,134,216,91,5,231,185,
140,210,48,110,237,179,81,15,78,16,242,172,47,113,147,205,
17,79,173,243,112,46,204,146,211,141,111,49,178,236,14,80,
175,241,19,77,206,144,114,44,109,51,209,143,12,82,176,238,
50,108,142,208,83,13,239,177,240,174,76,18,145,207,45,115,
202,148,118,40,171,245,23,73,8,86,180,234,105,55,213,139,
87,9,235,181,54,104,138,212,149,203,41,119,244,170,72,22,
233,183,85,11,136,214,52,106,43,117,151,201,74,20,246,168,
116,42,200,150,21,75,169,247,182,232,10,84,215,137,107,53
// Returns 0 for one wire device presence, 1 for none
int8 ow_reset(void)
int8 presence;
output_low(DQ);
delay_us(488); // Min. 480uS
output_float(DQ);
delay_us(72); // Takes 15 to 60uS for devices to respond
presence = input(DQ);
delay_us(424); // Wait for end of timeslot
return(presence);
// Read bit on one wire bus
int8 read_bit(void)
output_low(DQ);
delay_us(1); // 1uS min. Original code relied on 8051 being slow
output_float(DQ);
delay_us(20); // Wait at least 15mS from start of time slot
return(input(DQ)); // Delay to finish time slot (total 60 to 120uS)
} // must be done next.
void write_bit(int8 bitval)
output_low(DQ);
if(bitval == 1) {
output_float(DQ);
delay_us(105); // Wait for end of timeslot
output_float(DQ);
int8 read_byte(void)
int8 i;
int8 val = 0;
for(i=0;i<8;i++)
if(read_bit()) val |= (0x01 << i);
delay_us(120); // To finish time slot
return val;
void write_byte(int8 val)
int8 i;
int8 temp;
for (i=0;i<8;i++)
temp = val >> i;
temp &= 0x01;
write_bit(temp);
delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
dowcrc = dscrc_table[dowcrc^x];
return dowcrc;
// Searches for the next device on the one wire bus. If there are no more
// devices on the bus then false is returned.
int8 Next(void)
int8 m = 1; // ROM Bit index
int8 n = 0; // ROM Byte index
int8 k = 1; // Bit mask
int8 x = 0;
int8 discrepMarker = 0;
int8 g; // Output bit
int8 nxt; // Return value
short flag;
nxt = FALSE; // Reset next flag to false
dowcrc = 0; // Reset the dowcrc
flag = ow_reset();
if (flag||doneFlag) // If no parts return false
lastDiscrep = 0; // Reset the search
return FALSE;
write_byte(0xF0); // Send SearchROM command
do
x = 0;
if (read_bit() == 1) x = 2;
delay_us(120);
if (read_bit() == 1) x |= 1; // And it's complement
if (x == 3) // There are no devices on the one wire bus
if (x > 0) // All devices coupled have 0 or 1
g = x >> 1; // Bit write value for search
// If this discrepancy is before the last discrepancy on a previous
// Next then pick the same as last time.
if (m < lastDiscrep)
g = ((ROM[n] & k) > 0);
// If equal to last pick 1
g = (m == lastDiscrep); // If not then pick 0
// If 0 was picked then record position with mask k
if (g == 0) discrepMarker = m;
// Isolate bit in ROM[n] with mask k
if (g == 1) ROM[n] |= k;
else ROM[n] &= ~k;
write_bit(g); // ROM search write
m++; // Increment bit counter m
k = k << 1; // and shift the bit mask k
// If the mask is 0 then go to new ROM
if (k == 0)
{ // Byte n and reset mask
ow_crc(ROM[n]); // Accumulate the crc
n++;
k++;
} while (n < 8); // Loop through until through all ROM bytes 0-7
if (m < (65||dowcrc)) // If search was unsuccessful then
lastDiscrep = 0; // reset the last Discrepancy to zero
else // Search was successful, so set lastDiscrep, lastOne, nxt
lastDiscrep = discrepMarker;
doneFlag = (lastDiscrep == 0);
nxt = TRUE; // Indicates search not yet complete, more parts remain
return nxt;
// Resets current state of a ROM search and calls Next to find the first device
// on the one wire bus.
int8 First(void)
lastDiscrep = 0;
doneFlag = FALSE;
return Next(); // Call Next and return it's return value;
void FindDevices(void)
int8 m;
if(!ow_reset())
if(First()) // Begins when at least one part found
numROMs = 0;
do
numROMs++;
for (m=0;m<8;m++)
FoundROM[numROMs][m] = ROM[m]; // Identifies ROM no. on device
printf("Device No.%u address ",numROMs);
printf("%X%X%X%X%X%X%X%X\n\r",
FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5],
FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2],
FoundROM[numROMs][1],FoundROM[numROMs][0]);
} while (Next() && (numROMs<10)); // Continues until no additional
// devices found.
putc('\n'); putc('\r');
// Sends Match ROM command to bus then device address
int8 Send_MatchRom(void)
int8 i;
if (ow_reset()) return FALSE; // 0 if device present
write_byte(0x55); // Match ROM
for (i=0;i<8;i++)
write_byte(FoundRom[numROMs][i]); // Send ROM code
return TRUE;
I m using PCWH 4.064
All my code is on different post of the forum...
please help me ;( |
Posted: Thu Jan 17, 2008 2:09 pm |
| Quote: | | I don't think the error was in the main file or in the include for ds18b20/ds1822 but was in the variable declaration of the one wire device include file. | Don't assume but test!
I created the following test program | Code: | #include <18F2523.H>
while (TRUE) ;
Please note that we do like the short test programs very much. A large piece of code as you have posted takes way too much of our time to read, so most people will skip it and you don't get an answer...
Surprise!! I got an error on the same line of code as you did. I just get the strange feeling you could have performed the same test and now I'm doing your work...
Answer: Since compiler version 4 the ROM keyword is reserved and should not be used for variable names. It is a bad variable name anyway as it is not very specific about what data it contains.
More info on the ROM keyword from page 43 of the CCS manual: | Quote: | A special method allows the use of pointers to ROM. This method does not contain extra code at
the start of the structure as does constant..
For example:
char rom commands[] = {“put|get|status|shutdown”}; |
JULIEN LAFFITTE
Posted: Fri Jan 18, 2008 2:25 am |
Thank you
I'm sorry to have take your time for that , but now I know
Thanks again! |
