one wire search rom problem
JULIEN LAFFITTE
PostPosted: Thu Jan 17, 2008 11:34 am     Reply with quote
Hello
I m trying to implement the SEARCH ROM command on my application.
But when I compile a problem appear on this line, in the include for one wire device:
int8 ROM[8]; // ROM bit
I don't think the error was in the main file or in the include for ds18b20/ds1822 but was in the variable declaration of the one wire device include file.
Main file:
#include <18F2523.H>
#fuses   HS,NOPROTECT,NOBROWNOUT,NOWDT,WDT4096,PUT,NOCPD,NOSTVREN,NODEBUG,NOLVP,NOWRT,NOFCMEN//4s: WDT1024
#define DQ PIN_B1
#include <string.h>
#include <stdlib.h>
#include <owire_v2.c>
#include <ds18b20.c>
float temperature_c;
printf("connecting to DS1820 -----\r\n");
while (TRUE){
delay_ms(2000);
if (!ow_reset()) {
  // set the number of bits of resolution on the ds1822.
  // note that this affects the conversion time,
  // RTFM and see the called function.
  onewire_ds1822_set_temperature_resolution(12);
  // read the temperature from the ds1822.
  // note that the returned value is in deg C,
  // and the "lite" function returns only positive temps.
  temperature_c = onewire_ds1822_read_temp_c_lite();
  printf( "Temperature C= %10.2f degrees C \r\n", temperature_c ); // print temperature C
  delay_ms (1000);
  printf("onewire device not found\r\n");
}//end while(1)
}// end of main()
include for ds18b20 or ds1822:
// 16F877A Pin 33 (RB0) connected to DS1820 Pin2 (DQ).
// 16F877A Pin 33 (RB0) also connect to 4.7K resistor pulled up to +5V.
// 16F877A Pin 25 (RC6/Tx) connected to MAX232 which is then connected to PC serial Port.
// ds1822 scratchpad registers
#define DS1822_SP_TLSB  0
#define DS1822_SP_TMSB  1
#define DS1822_SP_HLIM  2
#define DS1822_SP_LLIM  3
#define DS1822_SP_CFG   4
#define DS1822_SP_RES0  5
#define DS1822_SP_RES1  6
#define DS1822_SP_RES2  7
#define DS1822_SP_CRC   8
// ds1822 rom registers
#define DS1822_ROM_DEVTYPE  0
#define DS1822_ROM_SERIAL1  1
#define DS1822_ROM_SERIAL2  2
#define DS1822_ROM_SERIAL3  3
#define DS1822_ROM_SERIAL4  4
#define DS1822_ROM_SERIAL5  5
#define DS1822_ROM_SERIAL6  6
#define DS1822_ROM_CRC      7
// ds1822 command set
#define DS1822_CMD_READROM           0x33
#define DS1822_CMD_SKIPROM           0xCC
#define DS1822_CMD_CONVERTTEMP       0x44
#define DS1822_CMD_WRITESCRATCHPAD   0x4E
#define DS1822_CMD_READSCRATCHPAD    0xBE
#define DS1822_CMD_COPYSCRATCHPAD    0x48
// note that not all applications need to disable interrupts when
// performing onewire transactions.  but, if unmasked interrupts
// cause onewire timing violations, returned data will be suspect
// or there may be other, hard-to-reproduce problems.
int onewire_ds1822_read_scratchpad(int field) { /* returns config bitfield */
   int data[9];
   ow_reset();
   write_byte(DS1822_CMD_SKIPROM);
   write_byte(DS1822_CMD_READSCRATCHPAD);
   data[DS1822_SP_TLSB]=read_byte();    // 0 Tlsb
   data[DS1822_SP_TMSB]=read_byte();    // 1 Tmsb
   data[DS1822_SP_HLIM]=read_byte();    // 2 Thlim
   data[DS1822_SP_LLIM]=read_byte();    // 3 Tllim
   data[DS1822_SP_CFG]=read_byte();     // 4 Config
   data[DS1822_SP_RES0]=read_byte();    // 5 RES0
   data[DS1822_SP_RES1]=read_byte();    // 6 RES1
   data[DS1822_SP_RES2]=read_byte();    // 7 RES2
   data[DS1822_SP_CRC]=read_byte();     // 8 CRC
   if (field > 8) {
      //printf(debug_putc,"ERR! >scratchpad field 0x%x out of range (ds1822)\n\r",field);
      return(0);
   else {
      //printf(debug_putc,"0x%x >scratchpad field 0x%x (ds1822)\n\r",data[field],field);
      return(data[field]);
int onewire_ds1822_read_rom(int field) { /* rtns ROM info, one byte at a time */
   int data[8];
   if (!ow_reset())
     return (0);
   write_byte(DS1822_CMD_READROM);
   data[DS1822_ROM_DEVTYPE]=read_byte();   // 0 family code
   data[DS1822_ROM_SERIAL1]=read_byte();   // 1 serial number LSB
   data[DS1822_ROM_SERIAL2]=read_byte();   // 2 serial number
   data[DS1822_ROM_SERIAL3]=read_byte();   // 3 serial number
   data[DS1822_ROM_SERIAL4]=read_byte();   // 4 serial number
   data[DS1822_ROM_SERIAL5]=read_byte();   // 5 serial number
   data[DS1822_ROM_SERIAL6]=read_byte();   // 6 serial number MSB
   data[DS1822_ROM_CRC]=read_byte();       // 7 CRC
   if (field > 7) {
      //printf(debug_putc,"ERR! >rom field 0x%x out of range (ds1822)\n\r",field);
      return(0);
   else {
      //printf(debug_putc,"0x%x >rom field 0x%x (ds1822)\n\r",data[field],field);
int onewire_ds1822_set_temperature_resolution(int resolution) { /* set up for nbit resolution */
   int resolution_cfgfield;
   if ((resolution < 9) || (resolution > 12))
      resolution=9;
   resolution_cfgfield=((resolution-9)<<5);  // see DS1822 datasheet page 7
   if (ow_reset())
     return (0);
   write_byte(DS1822_CMD_WRITESCRATCHPAD);
   write_byte(0b01111101);   // set max TH threshold (125'C)
   write_byte(0b11001001);   // set min TL threshold (-55'C)
   write_byte(resolution_cfgfield);    // Temp resolution, set to nbit
   ow_reset(); // reset
   write_byte(DS1822_CMD_COPYSCRATCHPAD);
   delay_ms(15); // allow time for flash memory write.
   return( (onewire_ds1822_read_scratchpad(DS1822_SP_CFG) & 0b01100000)>>5 );
float onewire_ds1822_read_temp_c_lite() {
   int temperatureLSB, temperatureMSB, config, delaymult;
   signed int16 temp16;
   float temperature;
   config=((onewire_ds1822_read_scratchpad(DS1822_SP_CFG) && 0b01100000)>>5);
      // each addn'l resolution bit needs twice the base conversion time!
   if (ow_reset())
     return (0);
   write_byte(DS1822_CMD_CONVERTTEMP);
   delaymult=1<<config;
      //printf(debug_putc,"0x%x >delay_mult (ds1822)\n\r",delaymult);
   while (delaymult--)
      delay_ms(100); // allow worst case time for temp. conversion.
   temperatureLSB = onewire_ds1822_read_scratchpad(DS1822_SP_TLSB);
   temperatureMSB = onewire_ds1822_read_scratchpad(DS1822_SP_TMSB);
   temp16= make16(temperatureMSB, temperatureLSB);
   temperature = (float) temp16 / 16.0;
   return(temperature);
// One Wire bus functions - from Dallas publication AN162
// "Interfacing DS18x20/DS1822 1-wire Temperature Sensor in a uC Environment"
// Delays calculated from values given for 8051 in source code
// Global variables
int8 lastDiscrep = 0;
short doneFlag = 0;
int8 FoundROM[7][8];    // Table of found ROM codes, 8 bytes for each
int8 numROMs;
int8 dowcrc;            // crc is accumulated in this variable
// crc lookup table
int8 const dscrc_table[] = {
   0,94,188,226,97,63,221,131,194,156,126,32,163,253,31,65,
   157,195,33,127,252,162,64,30,95,1,227,189,62,96,130,220,
   35,125,159,193,66,28,254,160,225,191,93,3,128,222,60,98,
   190,224,2,92,223,129,99,61,124,34,192,158,29,67,161,255,
   70,24,250,164,39,121,155,197,132,218,56,102,229,187,89,7,
   219,133,103,57,186,228,6,88,25,71,165,251,120,38,196,154,
   101,59,217,135,4,90,184,230,167,249,27,69,198,152,122,36,
   248,166,68,26,153,199,37,123,58,100,134,216,91,5,231,185,
   140,210,48,110,237,179,81,15,78,16,242,172,47,113,147,205,
   17,79,173,243,112,46,204,146,211,141,111,49,178,236,14,80,
   175,241,19,77,206,144,114,44,109,51,209,143,12,82,176,238,
   50,108,142,208,83,13,239,177,240,174,76,18,145,207,45,115,
   202,148,118,40,171,245,23,73,8,86,180,234,105,55,213,139,
   87,9,235,181,54,104,138,212,149,203,41,119,244,170,72,22,
   233,183,85,11,136,214,52,106,43,117,151,201,74,20,246,168,
   116,42,200,150,21,75,169,247,182,232,10,84,215,137,107,53
// Returns 0 for one wire device presence, 1 for none
int8 ow_reset(void)
   int8 presence;
   output_low(DQ);
   delay_us(488);          // Min. 480uS
   output_float(DQ);
   delay_us(72);           // Takes 15 to 60uS for devices to respond
   presence = input(DQ);
   delay_us(424);          // Wait for end of timeslot
   return(presence);
// Read bit on one wire bus
int8 read_bit(void)
   output_low(DQ);
   delay_us(1);         // 1uS min. Original code relied on 8051 being slow
   output_float(DQ);
   delay_us(20);        // Wait at least 15mS from start of time slot
   return(input(DQ));   // Delay to finish time slot (total 60 to 120uS)
}                       // must be done next.
void write_bit(int8 bitval)
   output_low(DQ);
   if(bitval == 1) {
      output_float(DQ);
   delay_us(105);       // Wait for end of timeslot
   output_float(DQ);
int8 read_byte(void)
   int8 i;
   int8 val = 0;
   for(i=0;i<8;i++)
      if(read_bit()) val |= (0x01 << i);
      delay_us(120);  // To finish time slot
   return val;
void write_byte(int8 val)
   int8 i;
   int8 temp;
   for (i=0;i<8;i++)
      temp = val >> i;
      temp &= 0x01;
      write_bit(temp);
   delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
   dowcrc = dscrc_table[dowcrc^x];
   return dowcrc;
// Searches for the next device on the one wire bus. If there are no more
// devices on the bus then false is returned.
int8 Next(void)
   int8 m = 1;             // ROM Bit index
   int8 n = 0;             // ROM Byte index
   int8 k = 1;             // Bit mask
   int8 x = 0;
   int8 discrepMarker = 0;
   int8 g;                 // Output bit
   int8 nxt;               // Return value
   short flag;
   nxt = FALSE;            // Reset next flag to false
   dowcrc = 0;             // Reset the dowcrc
   flag = ow_reset();
   if (flag||doneFlag)     // If no parts return false
      lastDiscrep = 0;     // Reset the search
      return FALSE;
   write_byte(0xF0);       // Send SearchROM command
   do
      x = 0;
      if (read_bit() == 1) x = 2;
      delay_us(120);
      if (read_bit() == 1) x |= 1;   // And it's complement
      if (x == 3)                   // There are no devices on the one wire bus
         if (x > 0)                 // All devices coupled have 0 or 1
            g = x >> 1;             // Bit write value for search
         // If this discrepancy is before the last discrepancy on a previous
         // Next then pick the same as last time.
            if (m < lastDiscrep)
               g = ((ROM[n] & k) > 0);
            // If equal to last pick 1
               g = (m == lastDiscrep);  // If not then pick 0
               // If 0 was picked then record position with mask k
               if (g == 0) discrepMarker = m;
         // Isolate bit in ROM[n] with mask k
         if (g == 1) ROM[n] |= k;
         else ROM[n] &= ~k;
         write_bit(g);  // ROM search write
         m++;           // Increment bit counter m
         k = k << 1;    // and shift the bit mask k
         // If the mask is 0 then go to new ROM
         if (k == 0)
         {  // Byte n and reset mask
            ow_crc(ROM[n]);      // Accumulate the crc
            n++;
            k++;
   } while (n < 8);  // Loop through until through all ROM bytes 0-7
   if (m < (65||dowcrc))   // If search was unsuccessful then
      lastDiscrep = 0;     // reset the last Discrepancy to zero
   else  // Search was successful, so set lastDiscrep, lastOne, nxt
      lastDiscrep = discrepMarker;
      doneFlag = (lastDiscrep == 0);
      nxt = TRUE; // Indicates search not yet complete, more parts remain
   return nxt;
// Resets current state of a ROM search and calls Next to find the first device
// on the one wire bus.
int8 First(void)
   lastDiscrep = 0;
   doneFlag = FALSE;
   return Next();    // Call Next and return it's return value;
void FindDevices(void)
   int8 m;
   if(!ow_reset())
      if(First())    // Begins when at least one part found
         numROMs = 0;
         do
            numROMs++;
            for (m=0;m<8;m++)
               FoundROM[numROMs][m] = ROM[m];   // Identifies ROM no. on device
            printf("Device No.%u address ",numROMs);
            printf("%X%X%X%X%X%X%X%X\n\r",
            FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5],
            FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2],
            FoundROM[numROMs][1],FoundROM[numROMs][0]);
         } while (Next() && (numROMs<10));   // Continues until no additional
                                             // devices found.
   putc('\n'); putc('\r');
// Sends Match ROM command to bus then device address
int8 Send_MatchRom(void)
   int8 i;
   if (ow_reset()) return FALSE;          // 0 if device present
   write_byte(0x55);                      // Match ROM
   for (i=0;i<8;i++)
      write_byte(FoundRom[numROMs][i]);   // Send ROM code
   return TRUE;
I m using PCWH 4.064
All my code is on different post of the forum...
please help me ;(
PostPosted: Thu Jan 17, 2008 2:09 pm     Reply with quote
Don't assume but test!
I created the following test program
   while (TRUE) ;
Please note that we do like the short test programs very much. A large piece of code as you have posted takes way too much of our time to read, so most people will skip it and you don't get an answer...
Surprise!! I got an error on the same line of code as you did. I just get the strange feeling you could have performed the same test and now I'm doing your work...
Answer: Since compiler version 4 the ROM keyword is reserved and should not be used for variable names. It is a bad variable name anyway as it is not very specific about what data it contains.
More info on the ROM keyword from page 43 of the CCS manual:
A special method allows the use of pointers to ROM. This method does not contain extra code at
the start of the structure as does constant..
For example:
char rom commands[] = {“put|get|status|shutdown”};
JULIEN LAFFITTE
PostPosted: Fri Jan 18, 2008 2:25 am     Reply with quote
Thank you Exclamation
I'm sorry to have take your time for that Embarassed , but now I know Idea
Thanks again!
