spom
stepping-motor control with PWM and L293D |
Posted: Tue Dec 04, 2007 5:07 am |
I use a Pic 16F818, a no name bipolar stepping-motor with 50 steps, and a L293D(http://www.ortodoxism.ro/datasheets/texasinstruments/l293d.pdf).
I want to generate a PWM signal with the Pic, and then the motor should rotate 50 steps left, and then 50 steps right.
My code looks that way:
#include <16f818.h>
#use delay(clock=8000000)
#fuses NOWDT,HS,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
setup_timer_2(T2_DIV_BY_4, 149, 1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(255L);
output_high(PIN_B0);
output_low(PIN_B1);
//50 steps and then turn around????
I don't know how to handle it that the motor change rotation after 50 steps.
Is the pwm right?
By the way: one inductor is connected to PIN 2 and 7 of the L293D and the other to PIN 10 and 15. Is that right?
Thanks! |
Posted: Tue Dec 04, 2007 5:17 am |
Basically, no.
The PWM, generates a continuous stream of pulses, allowing you to specify the mark space ratio. It does _not_ count pulses.
Almost exactly this question, was asked a while ago. A search should find it. Look for 'PWM stepper', asking the search to find 'all' terms, and you should get a number of threads about this. The simplest way for what you want,will be to ignore PWM completely.
spom
Posted: Tue Dec 04, 2007 11:25 am |
Thanks!
But I've still had a problem. I connected one inductor with B0 and B1 of the PIC and the second inductor with B6 and B7 of the PIC.
Now my code:
#include <16f818.h>
main()
int sequence[8] = {130,129,65,66};
int i=0;
int16 c=0;
delay_us(2000);
output_B(sequence[i]);
i++;
if (i>3)
c++;
i=0;
if (c==500)
c=0;
But it doesn't work! Why?
Thank you for your help! |
Posted: Tue Dec 04, 2007 3:38 pm |
Try reversing one coil. If you have the phase of one coil reversed, it'll just sit and move back/forwards a tiny amount.
spom
Posted: Sun Dec 09, 2007 6:38 am |
Sorry for my stupid questions again:
I changed my code accorgding to the example EX_STEP.C from CCS C and therefor my pin assignment:
#include <16f818.h>
#BYTE port_b = 6
#define FOUR_PHASE TRUE
#ifdef FOUR_PHASE
BYTE const POSITIONS[4] = {0b0101,
0b1001,
0b1010,
0b0110};
#else
BYTE const POSITIONS[8] = {0b0101,
0b0001,
0b1001,
0b1000,
0b1010,
0b0010,
0b0110,
0b0100};
drive_stepper(BYTE speed, char dir, BYTE steps)
static BYTE stepper_state = 0;
BYTE i;
for(i=0; i<steps; ++i) {
delay_ms(speed);
set_tris_b(0xf0);
port_b = POSITIONS[ stepper_state ];
if(dir!='R')
stepper_state=(stepper_state+1)&(sizeof(POSITIONS)-1);
stepper_state=(stepper_state-1)&(sizeof(POSITIONS)-1);
main()
BYTE speed, steps;
char dir;
while (TRUE)
speed = 20;
dir='F';
steps = 168;
drive_stepper(speed,dir,steps);
But the motor doesn't rotate. I feel an easy movement, but not 7.5°.
The contacts are right as the power supply fall down after switching on. So the motor need current.
Where is the fault?
Thanks! |
