more of a hardware question than software.
Im linking up an ENC28j60 to a PIC and noticed the ENC module draws 180ma. According to the chips spec sheet this is correct.(as I have yet to initialise it)
Is this a normal sort of operational consumption?
Is it just a thirsty chip or are most ethernet devices in the similar ball park?
I suspect the latter due to the amount of processing the device is required to do.
thanks
Vector
Posted: Fri Nov 30, 2007 2:25 am
I noticed the ENC module draws 180ma. Is this a normal sort of operational consumption?
