ethernet power consumption
vector
PostPosted: Fri Nov 30, 2007 2:08 am     Reply with quote
more of a hardware question than software.
Im linking up an ENC28j60 to a PIC and noticed the ENC module draws 180ma. According to the chips spec sheet this is correct.(as I have yet to initialise it)
Is this a normal sort of operational consumption?
Is it just a thirsty chip or are most ethernet devices in the similar ball park?
I suspect the latter due to the amount of processing the device is required to do.
thanks
Vector
PostPosted: Fri Nov 30, 2007 2:25 am     Reply with quote
I noticed the ENC module draws 180ma. Is this a normal sort of operational consumption?
See asmallri's post in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=30085&highlight=enc28j60+power
vector
PostPosted: Fri Nov 30, 2007 3:23 am     Reply with quote
thanks, not sure why my initial search missed that one
