		| Author | Message |
		| c0de
				| problem assigning port_a with input_a() |
				|  Posted: Fri Nov 23, 2007 6:48 am |   |
				| Hello.
 I'm trying to make a simple program to write the state of portA pins to a lcd.
  	  | Code: |  	  | #include <16F876.h> #fuses HS,NOWDT,NOPROTECT,NOLVP
 #include <flex_lcd.c>
 void read_port_a()
 int8 x;
 x = input_a();
 int inc=0;
 char bit[6];
 for (inc=0; inc<=5; inc++)
 if ( bit_test(x,inc) )
 bit[inc] = '1';
 bit[inc] = '0';
 lcd_gotoxy(2,3);
 printf(lcd_putc,"%c %c %c %c %c %c", bit[5],bit[4],bit[3],bit[2],bit[1],bit[0]);
 delay_ms(20);
 void main() {
 int i = 0;
 set_tris_a(0b00111111);
 delay_ms(20);
 printf(lcd_putc,"\f");
 printf(lcd_putc,  " PIC16F76  LCD  ");
 printf(lcd_putc,"\n -------------  ");
 printf(lcd_putc,"\n                ");
 while ( 1 )
 read_port_a();
 delay_ms(20);
 everytime I try to compile the code, i get this:
 Compiling:  cos_lcd.c
 1 Errors,  0 Warnings,  Time: 1 Seconds
 Error[51]   cos_lcd.c 10 : A numeric expression must appear here
 1 Errors,  0 Warnings.
 which is this line:
 ... I cannot figure what I'm missing
 using pic16f876 and PCM compiler version 4.032; (linux)
 Any help would be appreciated. Thanks
 EDITED:
 By some reason, i cannot define variables within custom functions. the program works if i define x, bit and inc variables globally (before the read_port_a function)
		| Ttelmah Guest
				|  Posted: Fri Nov 23, 2007 7:40 am |   |
				| You cannot declare a type once you have 'started' the function. All declarations must be at the beginning of the function block (or global).
  	  | Code: |  	  | void read_port_a() {
 //First the declarations
 int8 x;
 int inc=0;
 char bit[6];
 //Now the code
 x = input_a();
 for (inc=0; inc<=5; inc++) {
 bit[inc] = '1';
 bit[inc] = '0';
 lcd_gotoxy(2,3);
 delay_ms(20);
 Technically you could declare variables inside a sub function
 (so have a leading '{', then a declaration, then more functions, and a trailing '}'), but in CCS, these are not identified as separate variables, so should be used with care.
		| c0de
				|  Posted: Fri Nov 23, 2007 10:10 am |   |
				| I didn't knew that:) Thanks alot.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
