problem assigning port_a with input_a()
c0de
PostPosted: Fri Nov 23, 2007 6:48 am     Reply with quote
Hello.
I'm trying to make a simple program to write the state of portA pins to a lcd.
#include <16F876.h>
#include <flex_lcd.c>
void read_port_a()
    int8 x;
    x = input_a();
    int inc=0;
    char bit[6];
    for (inc=0; inc<=5; inc++)
   if ( bit_test(x,inc) )
           bit[inc] = '1';
       bit[inc] = '0';
    lcd_gotoxy(2,3);
    printf(lcd_putc,"%c %c %c %c %c %c", bit[5],bit[4],bit[3],bit[2],bit[1],bit[0]);
    delay_ms(20);
   int i = 0;
   set_tris_a(0b00111111);
   delay_ms(20);
   lcd_init();
   printf(lcd_putc,"\f");
   printf(lcd_putc,  " PIC16F76  LCD  ");
   printf(lcd_putc,"\n -------------  ");
   printf(lcd_putc,"\n                ");
   while ( 1 )
      read_port_a();
      delay_ms(20);
everytime I try to compile the code, i get this:
Compiling: cos_lcd.c
1 Errors, 0 Warnings, Time: 1 Seconds
Error[51] cos_lcd.c 10 : A numeric expression must appear here
1 Errors, 0 Warnings.
which is this line:
 int inc=0;
... I cannot figure what I'm missing
using pic16f876 and PCM compiler version 4.032; (linux)
Any help would be appreciated. Thanks
EDITED:
By some reason, i cannot define variables within custom functions. the program works if i define x, bit and inc variables globally (before the read_port_a function)
PostPosted: Fri Nov 23, 2007 7:40 am     Reply with quote
You cannot declare a type once you have 'started' the function.
All declarations must be at the beginning of the function block (or global).
void read_port_a() {
    //First the declarations
    int8 x;
    int inc=0;
    char bit[6];
    //Now the code
    x = input_a();
    for (inc=0; inc<=5; inc++) {
           bit[inc] = '1';
           bit[inc] = '0';
    lcd_gotoxy(2,3);
    delay_ms(20);
Technically you could declare variables inside a sub function
(so have a leading '{', then a declaration, then more functions, and a trailing '}'), but in CCS, these are not identified as separate variables, so should be used with care.
c0de
PostPosted: Fri Nov 23, 2007 10:10 am     Reply with quote
I didn't knew that:)
Thanks alot.
